August 2016 Chat
#121
Dang, they did hit something pretty hard.
I got the AC working in the 79 on Sunday. It's not new car cold but it's pretty cold for not working in who knows how long. At least 5 years I know of. The front left tire keeps going flat, the valve core was loose but my tool was at work.
Where are the pics. Have you ever heard of somebody hitting a deer and leaving no blood or hair on the car. While we were on our cruise the former friends that "Watched the house and critters" was usin my 07 Liberty. Get home there is lt rear tail light is busted, the spare is on the ground the other tire has a big hole in it and the rt rear bumper corner is pushed in. " Somebody ran them of the road" Go around front the grill is cracked headlight is just stuck in the hole , the turn signal is busted and fender is pushed in a little " they hit a deer"
OFFERED TO PAY NEVER HAPPENED
Took it apart found the plastic piece behind the grill busted never found any hair or blood. Ordered that piece a set of headlights, turn signal and tail light fiberglassed the back side of the grill still got to get tires
Wasn't happy
Wasn't happy
As a matter of fact. here come pics
#122
I hit a 16pt doing 75 on I16 5 years ago in my suburban. No blood, or ****, just a small amount of fur. Head went one way, and body went the other then a semi ran over the body shortly after......
cracked block and trans, see the driveshaft as well
another angle
bent axle, broken axle shaft
bent axle
here is your deer hit. Supposedly a 10-12pt <br/>No blood, no poop
Same deer car, torn down, no blood no poop
another angle
bent axle
#125
In your case that was horse****. Deer hits are always front impact, or the deer runs into the side of the car but only affects 1-2 panels.
#127
on
I have been getting better and bigger tools for work but a second set for the house is going to be a must. Even if it's a cheap set from harbor freight. Not so bad this week, I must be getting use to working for a living again.
#131
That is the most intestine rivet gun I ever seen. One person can buck solid rivets.
The speciality tools you have to go with the biggies .
On hand tools there are only a handfull of tool and die makers
#132
Its actually a door skin tool. HAHA. I have a huge air hammer that will cut 1/2 rivets out of a frame like butter. I use it to cut through frames and structures with ease.
#133
FORD FIRED TODAY!!!!!!! Sounds intensely mean. Very deep, very loud. But need to fine tune the A/F mix. No leaks, nothing. Finally all that work, I have a strong running motor.
