New to the group looking for ideas
So I've got a 78 f150 302 I Put on a edelbrock intake and four barrel carb (1403) at first I thought I had bad gas but now I'm thinking maybe vacuum leak causing this,timing I'm shooting in the dark here as I put on headers this summer can't seem to get it working right when I floor it it spits and spudders its defently over feeling but no gas in oil just changed last night
Get a can of spray carb cleaner and spray all over the intake while it's running, if you have a leak, you've hear the engine change pitch when the cleaner gets sucked into the leak. Did you reset the ignition timing when you put it back together ? What did you set the initial timing at ? Did you adjust the carb when you bolted it down ? (after setting the timing ?)
Gave the carb a rebuild kit
plowboy12
02-15-2014 02:00 AM
fordfanatik
13
03-10-2012 11:26 PM
82f100460
01-29-2012 05:04 PM
LTTLMAN
02-12-2005 04:00 PM
