What size wrench do I need to undo my rear brake lines?
Hello, just tried replacing my wheel cylinders which involves disconnecting the rear brake lines... long story short I broke the end of the line off. I was using vise grips and hind sight being 20/20 I should have used a wrench. Does anyone know what size wrench to use so I dont break the other side as well?
Penetrating oil? You could try to take the bolts out that hold the wheel cylinder to the backing plate so you can get a better purchase on the flare nut. I would only use vise grips if all else fails.
