New Ford/bronco owner
The bellhousing from the 400 is different. However the bellhousings on the older 4 speeds are detachable. Everything else will work, but you will need to acquire a bellhousing from either a 300 inline six, or 302/351w. Your best bet would be to find the aluminum one from an 84-86 truck or Bronco. This will have the provisions for a hydraulic clutch setup. Then you locate a clutch/brake pedal assembly for a 92-96 truck or Bronco (pretty common) and you should be in business. Also the t-case from that 83 will most likely be the NP208. Fortunately Ford NP205s are pretty common, and will bolt right up with only slight modification of the intermediate housing. Hope this helps.
Ha! Thanks! "Nice" is subjective though. She will be functional, safe and reliable when I'm done. Just need to get that soul sucking power sponge auto out of there!!
Ok the 84-86 bell housing is desired because it is aluminum and setup for hydraulic clutch? Will other year iron BHs have the hydraulic clutch provisions? Also will the clutch and flywheel work from a 400? I'm sure all this info is out there, but since I have you here.... I'm gonna ask buddy for just the tranny if that's the case.
Yeah, they definitely grow on you very quickly. Lately I've had thoughts of parting ways with my 79. Then I jump up in it and hear and feel the power of the 460, I can't help but grin a little every time I hear the pipes. Not to mention, these rigs get looks and attention. Some good, some not so much. And it doesn't matter if it's bone stock, rust bucket, wheeler, or a show truck. Everywhere you go with a Bronco, there is always someone who takes notice of them. My wife and I get a kick out of taking ours out for a cruise through town or down by the beach. It ain't pretty but it still gets a lot of looks and thumbs up from people. After having owned a Bronco for several years, I would say they are probably the best all around 4x4s out there.
I used to camp in the back of mine a lot. You'd roll the window down and get in the back. Then quickly realize you had no way to roll it back up, so you climb over the seats to roll it up from the front. Then climb back over the seats to the back. Fold the back seat up to get more room and the latch is dead center where you are laying down instead of on the sides.
Same with the tailgate. Roll down window, open spare tire rack and tailgate, prop grocery cart against it to keep it from hitting car next to you, etc.
I love the fold flat floors, rear window and tailgate and ease of entry for back row passengers in my expedition, but if I had to trade one then the bronco is staying right where it's at. My wife knows she will go before it does, so she only asked to get rid of it one time lol.
Is been a few days since I updated this thread
Waiting on my new body mounts so I removed the core support and started repairing it. Just picked up my welder from a friend so things should start moving along again.
The FSM said I needed to drain the rad to get the core support out...pfff, what do they know.
Well, pretty much have the truck back together. Just need to drill some holes for the bumper and bolt it on.
I'm liking it much better(at least the looks) without the hokey body lift. Hoping to drive it to work tomorrow.
How I got it
Lots of room still, should be able to fit 37s with some trimming
The bumper wasn't built for a bronco, I might end up removing the upper outer tubes later on.
My other toy, I'll be installing a 3" lift on her next week.
How I got it
Inline 6?
Looking at this 90 f150 as a parts truck. Has a 4 speed, i6, 4x4
Worth it??
Is the i6 4 speed combo a good match for a bush truck?
1990 ford f150 4x4 Sooke, Victoria - MOBILE
Worth it??
#29
Inline 6?
Worth it??
Worth it??
