Bracket ID Help
Bracket ID Help
This bracket is in the engine compartment, drivers side and it basically holds the fuse box. the front side of the bracket bolts up to the fender and the the bracket goes out and around the fuse box. Please see the pics. First pic has the arrow pointing to the bracket and the end points circled.
Any idea what its name is or a part number for it? I've already ordered one incorrect bracket so i'm looking for a positive ID if you can get one.
Thanks!
Thanks!
Agreed - and thank you for your help! I've paged through so many of these pics but cna't seem to find it. I fear calling FORD and trying to walk them through it!
The bracket i have is OK, just has one section that is a bolt up that is rusted/broken so i was hoping to replace it. I guess we will need to live with it or go junk yard diving
There are two pics of the air cleaner, I looked at both, neither shows the bracket the OP wants.
Y'all with matching trucks should look on the bracket to see if it has an ID engineering number stamped on it.
BigBlack71
02-27-2011 06:14 PM
pod4
09-16-2002 11:13 AM
