i put a HEI distributor in two years ago. I bought it from a local machine shop for $100. It works great. It's probably a Chinese eBay one. However I do want to go with Davis unified ignition. They will change out the advance springs for your application. The only down side is the cap is HUGE and I had to grind my t stat housing and slot one of the bolt holes so I can slide it on and off with out pulling the dizzy itself.
At one time I did have an HEI distributor in Ka'Bluey, but when we did the engine swap, there was a difference in the shaft, so I couldn't use it.
But right from the beginning there was a huge improvement. I bought mine off of ebay,, 8 or 10 years ago.
I am using one from Summit. Works great and only uses 2 wires. Only thing is, it sits up much higher than stock so I had to go with a smaller air filter.
The HEI is a great way to go. Your engine compartment is cleaner that the outside of Ka'Bluey.
I have a feeling there's something to the pink under the hood.
I just put a Proform HEI from Advance Auto in my 302. It has worked perfect and I haven't looked back. I went through 3 brand new distributors, 4 new boxes and 3 coils to keep getting intermittent spark, switched to hei and she never misses a beat.
I know this is an old thread, but I just order my HEI dizzy from summit - what do I need to do different to wire it in... I bought the HEI adapter.
I'm running the Summit HEI. SUM-850025. Had it a little over a year and I have no complaints. It is a little large, so you may have to play with your air cleaner setup. I also had to clock it 90 degrees counter-clockwise to clear a Holley 4150. But if you're running a Motorcraft 2150, Edelbrock, or one of the cheaper Holley's you won't have to clock the distributor.
not mine but here is example of water neck tightness
Reason: davis unified sells an off set air cleaner housing ,allowing you to run a 3 inch x Fourteen air cleaner
Cool, that is the one I ordered! I am still running a Motorcraft 2150 for now. My question is with the wiring on installation: Am I assuming right that this will bypass the ICM? or rather, how do I properly wire it in (2 wires vs. the OME 3-wire). is there a install diagram for the 400m motor?
