Is the torsional rigidity issue true with all '11-'16 Super Duties?
theres a lot of chasis mis alignment going on when the flexing occurs...one of the causes of repeat radiator leaks as the radiator becomes the recipient of torsional loads.
boxing in the chasis on newer models is an obvious attempt to back stroke quietly while fixing this.
on my 2010 I installed a front hitch which bolts both front chasis ends together and provides a cross beam....reduces front flexing .
Torsional rigidity is a design choice. They could make the truck stiff as hell, or like a wet noodle. The video only shows that Ford's engineers decided to allow the frame to flex more than GM's engineers decided to allow their frame to flex.
It's only an issue if it causes a problem. The radiator thing could be an example if the frame flex is really the cause.
Look at Unimogs, their beds are mounted at only three points so that their frames can flex MORE to allow the wheels to stay on the ground longer in rough situations.
The only one of Chevy's videos that has made any impact on me at all is the tool box dropped in the bed. That seems like a VERY reasonable thing to have happen and the damage to the F150 bed was substantial. I would like to see that same test done with a spray on and also a drop-in bedliner, for comparison.
-J
-J
The frame "twist" is about half an inch higher in the SD VS Chevy. I can hardly see this as a disadvantage in real life highway/city situations.
Silverado 2500 HD refuses to twist with the Ford F-250 [News] - The Fast Lane Truck
I remember the days when frame flex was good to have. If you're loading your truck to max and driving through drainage ditches then you'll have issues, but if you are going to do that maybe a bone stock truck isn't for you. All these test are designed to push the vehicle to it's breaking point, every brand has them.
jpeters1
1999 to 2016 Super Duty
04-02-2011 09:08 AM
