Titan Tank Question - Ford Truck Enthusiasts Forums
Titan Tank Question
Old 07-30-2016, 02:55 PM
erik512 erik512 is offline
erik512 is gaining momentum as a positive member of FTE.erik512 is gaining momentum as a positive member of FTE.
Titan Tank Question
Hi all;
In the middle of installing a 50gal Titan Tank in my '15 6.7 CCSB, and had a question for anyone else that's done it. When the tank arrived, the box looked like it'd been air-dropped from a cargo plane directly onto the runway. When I opened everything up and inspected it, everything looked fine; However, I'm in the middle of installing it now, and as I was swapping the fuel pickup from the old tank to the new one, I noticed that it looks like the metal straps (which Titan ships IN the tank) chewed up the bottom of the new tank pretty cool (eg. if I run my hand along one of the edges of the new tank, it's.. chewed up plastic). I picked out all the small bits that I could find to clean it up.
Is this normal? Should I be worried about this? I mean, I guess it's plastic, so I'm not worried about the integrity of the tank, more wondering how concerned I should be any of this plastic gets sucked up in the future.
Thanks in advance!
Erik
Old 07-30-2016, 03:08 PM
Poorly taken in-tank photo for reference:
Old 07-30-2016, 03:50 PM
Iowa Ford's Avatar
Iowa Ford Iowa Ford is online now
Iowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputation
erik512, it will be fine just get it wiped out and put it together.
I have installed two of them and both had some scuffing of the plastic.
I have since changed the fuel filters on both trucks, and found a couple small black specks that made it to the filter. I guess that's what the filter is for !!
You will love the Titan !
Old 07-30-2016, 03:54 PM
Thanks! I should have added that I just installed a Dieselsite filter this morning too, so I guess I can keep an eye on those filters as well just in case anything gets sucked up.
Thanks for the help, going to go finish assembling this thing!
Old 07-30-2016, 05:27 PM
Just Strokin Just Strokin is online now
Just Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to behold
Yea. clean the tank with a vac and you should be ok.
Make sure you tighten the nuts for the fuel sending/pump per the installation instructions. Let sit and tighten again. I pressure tested mine to make sure.
Just for future reference to those to have the Titan tank and want to add a Dieselsite filter. It is easier to install the Dieselsite filter prior to installing the tank, but it can be done without dropping the Titan tank. It is tight for big hands but can be done.
Old 07-31-2016, 09:26 AM
Ford_Doctor's Avatar
Ford_Doctor Ford_Doctor is offline
Ford_Doctor is a name known to allFord_Doctor is a name known to allFord_Doctor is a name known to allFord_Doctor is a name known to allFord_Doctor is a name known to allFord_Doctor is a name known to all
Agreed that the tank is fine and to clean it thoroughly. I would however pick up the phone and call Titan and let them know what happened with the straps and that they should consider making changes to avoid this concern.
Old 07-31-2016, 12:10 PM
porthole's Avatar
porthole porthole is offline
porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.
My straps were wrapped up pretty good IIRC. But, at the price of these tanks there is no excuse for less then perfect delivery, including having all the debris out of the tank before shipping.
I don't mind a wipe down with a fuel wet towel, but sometimes the amount of debris is just carelessness. And if they can be careless with that ........
Old 07-31-2016, 12:58 PM
Yeah, agreed there. Seems like it'd be more ideal to just ship the straps in a separate box (and for what these things cost, that doesn't seem unreasonable). Then they could ship these things sealed and clean.
I cleaned it out as best I could and put it all together - so far, so good! I'll wait a week or two and change out the fuel filters just to be sure.
Thanks again for the help.
-Erik
Old 07-31-2016, 01:13 PM
The problem is partially Titan on packaging but also sounds like the shipping company caused the damage in how negligently the tank was handled when in their possession...
Old 07-31-2016, 02:07 PM
Yeah, it's very possible that UPS is sick and tired of carrying heavy truck parts up the driveway, and took it out on my Titan Tank..
Just went and filled up, can't find any leaks, so I'm declaring victory.
-Erik
Old 07-31-2016, 04:44 PM
Fantastic!!! I know you will like the added capacity.
Old 07-31-2016, 05:06 PM
ZooDad's Avatar
ZooDad ZooDad is offline
ZooDad is a splendid one to beholdZooDad is a splendid one to beholdZooDad is a splendid one to beholdZooDad is a splendid one to beholdZooDad is a splendid one to beholdZooDad is a splendid one to beholdZooDad is a splendid one to behold
I filled up my "new" Titan 65. Took 58.5 gallons. Just under $135.**
Still loving the range though.
Old 08-01-2016, 11:03 AM
Nice! After filling up every ~250 miles while towing my small UTV trailer around, I'm looking forward to enjoying the greater range.
RE: the little plastic bits in mine - I drove around (maybe 20 miles), and then let some fuel out of both the factory water separator and the dieselsite bowls; I found a few little plastic flecks in both. Not too much, but maybe 4-5 little 1-2mm pieces. I'm hoping that with the number of fuel filters I have now, that'll be a non-issue. I'm planning to go on a long-ish trip in the near future, so once I get back and go through a few tanks of fuel, I'll change all the filters and see how they look.
Cheers,
Erik
Old 08-01-2016, 03:14 PM
MG250 MG250 is offline
MG250 is starting off with a positive reputation.
Curious - How much is the tank and what would a ballpark price be to have it installed?
Old 08-01-2016, 04:46 PM
Ultratravler Ultratravler is offline
Ultratravler is starting off with a positive reputation.
I have a question also, if no one minds. Have any of you compared the plastic Titan to the metal Transfer Flow tanks? Thanks for any opinions.
Dave
6.7 w/ DieselSite Filter DFCM whining/buzzing/whirring erik512 6.7L Power Stroke Diesel 20 01-06-2017 11:00 PM
Titan tank question Lawrencew 6.7L Power Stroke Diesel 5 03-22-2016 08:21 PM
Question about Titan tank, any manufacturer members here Ace_boy2786 1999 to 2016 Super Duty 1 07-30-2015 04:15 PM
Titan Plastic Fuel Tank wmiller5 6.7L Power Stroke Diesel 9 05-16-2013 04:27 AM
Need Help ASAP! Titan Tank install gone Wrong Doonz 6.7L Power Stroke Diesel 13 01-10-2013 12:51 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
