Stuck Spark Plugs
Stuck Spark Plugs
Been changing spark plugs since I was 12. Never had a problem getting any out. Until now. 300-6, they're rusted in. The first one I have broken off the ceramic. Tried air impact on low setting. Gave them a good soaking of PB. Will let them soak awhile. They go in at an angle, hard to get a good bite on them. Would the air impact turned up full blast cause bad things to happen?
Dan
Shamelessly stolen from (somewhere) on the world wide web:
I've done some reading on the net about what the most potent penetrating fluid is, and ran across this study that I thought I'd share. Sorry if this has already been posted but it might help someone out. Be aware that acetone will lift/destroy any paint it comes in contact with, but with heavily rusted parts that's probably the last of your worries.
Freeing frozen fasteners
For all of you that are mechanically inclined and dealing with frozen fasteners:
Penetrating Oils Compared
Machinist's Workshop magazine actually tested penetrants for break out torque on rusted nuts. Significant results! They arranged a subjective test of all the popular penetrants with the control being the torque required to remove the nut from a "scientifically rusted" environment.
Penetrating oil .......... Average load
None ..................... 516 pounds
WD-40 .................... 238 pounds
PB Blaster ............... 214 pounds
Liquid Wrench ............ 127 pounds
Kano Kroil ............... 106 pounds
ATF-Acetone mix............ 53 pounds
The Automatic Transmission fluid (ATF)-Acetone mix was a home brew mix of 50/50 automatic
transmission fluid and acetone.
Note the "home brew" was better than any commercial product in this one particular test. A local machinist group mixed up a batch and all now use it with equally good results. Note also that Liquid Wrench is about as good as Kroil for about 20% of the price.
Based on the location of that plug its the front one. There is plenty of room to get the old torch in there and heat thing up, if you need to. The last time I did I6 300 plugs it was the back plug that I had trouble with. Some penetrating oil and a little time did the trick. Good luck and let us know how you made out.
I think that's why he posted the list.
CHANGE PLUGS MORE OFTEN. WELD EXHAUST MANIFOLD TO HEAD. NO GASKET REQUIRED. BOLT ON ANOTHER HEAD. FIT ANOTHER ENGINE. BUY ANOTHER TRUCK. WELL SOMETHING WITH A COMPUTER, TO DRIVE ITSELF FOR YOU. JUST TRY HARDER, THINK FOR YOURSELF. YOU DON'T NEED YOUR HAND HELD. YOU CAN DO IT WE ALL HAD TO START SOMETIME. NO SILLY QUESTIONS ONLY SILLY ANSWERS. GOOD LUCK. PLEASE IGNORE MY RANT. APOLOGIES.
The guy has a legitimate problem: A plug won't come out.
Can you restate your rant in simple terms and help him?
