Serpentine belt squeak
Finally got my trans all straightened out and now I have the legendary Ford belt squeak not only at WOT but at half throttle and above! My Gates belt is only a year old with less than 10k so I installed a brand new idle pulley and tensioner today from Ford and it still does it. Heard gator back belts would help but I was told by two performance shops that I should install a 1" smaller belt than stock that's what they do on Fords that have this issue or install a manual tensioner from a mustang/Ford lightning
Stock length gator back didn't help, exchanged it for a 1" smaller gator back and that didn't help! So I put a 1" shorter Gates belt on and my squeak at full throttle shifts are almost now completely gone. So what should I do to get it gone completely? Was told by a shop that's works on mustangs and lightning that my next option is too install a manual tensioner...
Hmm can't help. I had a squeak issue only once, it was on my '99 7.3 and even though the belt was newer I replaced it with a Gatorback and the squeak was gone. Since then whenever I replace a serpentine I use a Gatorback and I've never had a belt squeak. That's why I had recommended trying one.
And I know I'm not the only one with this problem. If you go on any Ford website Wethersfield it's a truck or Mustang site this is a normal problem. Mustang and lightning fixs are 1" smaller belts and in high hp motors manual tensioner. On pickup sites no one seemed to find a fix from what I've read so far
I soaked them with simply green and scrubbed them, rinsed and dried and then redid them a second time. Checked all the pullies, brand new idler and tensioner and 1" smaller belt and it's almost gone but under WOT it still squeaks just not nearly as bad as it was. This has me so annoyed and literally about to go mud bogging after work and dunk this truck a couple dozen times and teach her if she messes with me I'm gonna do it right back LOL
powerstroker100
15
07-10-2015 02:46 PM
87wreckerman
22
02-01-2009 04:09 AM
