AC problems
AC problems
Good Morning,
I have an 04 Ex, Limited, dual air, 158k. Recently the air has started blowing a little warm while sitting still but under way it is nice and cold. I have checked my AC low pressure with a cheap can gauge, all I had available at the time, it registered 65 psi at idle, outside temp was around 97.
I have thought about tearing the system down, replacing oriface tube, replacing o-rings, cleaning out the entire system, replacing coolant and seeing if that was any better. I have also considered installing a couple of electric fans in front of the condinser with a relay which would turn them on anytime the compressor is running. I saw this setup on an Ex in Florida, owner said it worked really well for him.
Anybody else have any suggestions or recommendations.
Thank you,
Jeff
Thank you,
Jeff
https://www.ford-trucks.com/forums/1...l#post15048442
Would be worth checking the clutch fan.
Also worth reading: http://springerpop.com/F350/air_gap.html
Agreed. My Ex puts out 50psi on the low side and 250psi on the high side with a mostly worn out compressor that makes pretty good noise, if that is any help. You can get the gauges anywhere that sells car parts usually and its easy to take a reading. My A/C is marginal in the Arizona heat when idling and mostly OK going down the road.
65 is too high for that temperature. However you also need to know what the high side pressure is. If they're both too high you're overcharged or under-cooled at the condenser.
Otherwise with the suction side not dropping like it should I'd expect a slipping clutch or worn out compressor.
Really just SWAGs here though without having the full picture.
