fuel tank selector valve screen / filter location? - Ford Truck Enthusiasts Forums
Old 07-27-2016, 03:37 PM
Ezalycasaid's Avatar
Ezalycasaid Ezalycasaid is offline
Ezalycasaid is starting off with a positive reputation.
Sorry to keep making new posts but there doesn't seem to be a single post on the Internet with this as the subject.
I was told there is a screen or filter on our fuel tank selector valves that get clogged. Where is the screen? Is it inside the plastic body of the valve? Is it before u get to the valve itself? Any if would be helpful, thanks.
Old 07-27-2016, 04:13 PM
97-psd's Avatar
97-psd 97-psd is online now
97-psd is gaining momentum as a positive member of FTE.
Hmm. I have never heard that before. Maybe they were talking about the pickup sock/shower head in the tank? If you searched the whole internet and couldn't find any matches that may be another indicator that it does not exist.
If it does exist, I have never heard of anyone having trouble with it
Old 07-27-2016, 04:24 PM
knottyrope's Avatar
knottyrope knottyrope is offline
knottyrope has a good reputation on FTE.knottyrope has a good reputation on FTE.
pickup sock/shower head in the tank breaks and gets stuck in the valve from what I have read
Old 07-27-2016, 05:40 PM
mcali2's Avatar
mcali2 mcali2 is online now
mcali2 is gaining momentum as a positive member of FTE.mcali2 is gaining momentum as a positive member of FTE.
inside the fuel tank at the end of the pickup tube. 35$ for a new one. doubt its clogged. its about the size of beer can end and is just a screen. they brake off the pickup tube and can cause loss of pickup of fuel when the fuel gets lower than the tube but not much.
Old 07-27-2016, 08:02 PM
Ok thanks guys. It sounds like I got 2 different things confuzd. I must have read something saying there's a screen in the tank, sometimes the selector valve gets plugged. And put the two together. Anyway thanks again.
Old 07-27-2016, 09:17 PM
krifenbu's Avatar
krifenbu krifenbu is offline
krifenbu is gaining momentum as a positive member of FTE.krifenbu is gaining momentum as a positive member of FTE.
There is a screen in the fuel pressure regulator.
Old 07-28-2016, 10:58 PM
97-psd's Avatar
^^^ this may be what you were thinking of. It is inside of the fuel bowl. it can become dirty and need cleaning. It is pretty easy to do.
Does it have a fuel selector valve or not?? Jonnys.1991 1987 - 1996 F150 & Larger F-Series Trucks 5 04-11-2016 09:18 PM
WTB IDI Fuel Selector Valve jayro88 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 09-28-2013 08:03 PM
6 port fuel selector valve Hopsing69 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 07-28-2013 10:03 PM
fuel tank selector valve maxwell2425 1987 - 1996 F150 & Larger F-Series Trucks 5 01-09-2010 10:20 PM
Fuel Tank Selector Valve sckirklan Fuel Injection, Carburetion & Fuel System 4 06-06-2009 06:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
