Brakes in NC
Brakes in NC
Hello again
The bad penny shows up again. Sorry
Looks like every time I show up here I have a problem. This time it is the brakes on my 1995 F 250 ford Ext. cab 4x4 auto trans. XLT.
I have lost all brakes on this truck. When I mash the brake pedal there is a loud whoosh of air sound coming from down under the dash at the brake pedal.
Also the brake fluid has a very dark color to it.......all most black.
The issue I have is I think I know how to repair all these issues But my body and age will not let me do this work which sucks.
Does anyone know a good mechanic in the central NC area that can be trusted to do this work at a fair price.
My brain tells me to do this myself but working off the ground in 100* heat in the front yard is telling me not to try.
I am not sure about the whoosh sound issue.
Dark brake fluid is all rubber flex lines need to be replaced. Steel lines need to be cleaned out.
Calipers and wheel cylinders drained and checked out
Master cyl. needs to be cleaned.
Check pads, rotors, drums and shoes.
Is there anything I missed???
How much should this cost???
Getting Old sucks for us and our old PSD trucks.
RABS valve test is needed and don't forget to bleed it too.
https://www.ford-trucks.com/forums/1...ake-valve.html
Sounds like your booster is broken
if flex lines are cracking then replace them
If you know how to do it, then teach someone else and let them do the work for you.
Yes. I would love to find someone that could use what knowledge I have gathered in the last 70 yrs.
I am sure I have all the tools to do all this type of job. I had a birthday 4 days ago and did get a call from my son. The wife bought me a 2 liter Dr. Pepper
The older you get the less young people you know even if it is from your own family...
That is why I am looking for a good mechanic to work on my truck.
I swear the more I think about this ......the more I am thinking of starting this project myself...........if it kills me
I have stints in my heart, both hips are shot, right knee hurts all the time. I take heart meds..blood pressure and 40 mgs. of Oxycodone per day. And still can not walk 100 yards.
What do ya'll think????
Did this happen all at once or slowly over time? If it was all at once then I would lean towards the brake booster being the culprit. As far as doing it yourself. Can the truck be down for a few days without an inconvenience for you? If so, go for it! Work until you get tired, take a break, then go back at it. Even if it takes a few days it would a fun project if you feel up to it. Good luck!
OK.....
Ya'll have got me thinking...I can do this
I need to read up on what parts I should use on this 1995 truck. Like a 1997 booster, flex steel lines or oem type.
Any good parts info would be a great help..........Looking to get everything on line since I do not want to ride my moped 7 miles one way to the parts store.........LOL]
I will look at your Lakeland parts site.........Thanks
Going to start getting everything ready to start this project......Plywood, floor jack, safety stands, impact guns and tools gathered up
Plus my big Gun....incase I get mad and have to shoot the damn thing a few times
You guys are great.
You guys are great.
Morning to you guys
Bill, thank you again for finding out what was wrong with my truck the last time you were down here with your computer. It has ran great until my wife drove it Sunday. When she got home she said that it was making a clicking noise from the right side and it wanted to pull to the right sometimes when she stopped.
Yesterday I went out there to see if I could find anything wrong. I started the truck, it sounded great as usual. Let it idle until the GP kicked off, then went to put in gear and when I mashed the brake petal a loud whoosh sound came from down at the foot brake and it went to the floor.....no brakes
My wife can tare up an anvil with a feather duster. Just glad she got home safe with the old truck.
Is there any truth to using a 1997 booster or is that just someone bumping their gums.
one more question.......please
I can only use 6 gal. of fuel out of rear tank before it runs out of fuel. How bad is that to repair????
Bad booster was my first thought also, until you posted the pedal went straight to the floor. Sounds like a bad master cylinder or major leak.
As for the fuel problem.
Fuel pickup. Sender assembly will need to come out of tank. If I remember correctly, it's the rear tank that has to be dropped to get it out.
OK.....
You guys are great.
You guys are great.
Thanks Bird
I will look into that.....What is your name @ Lakeland ford parts???? and yes I would like to talk to you about some of these parts. If I knew who I was talking to.
I was afraid of the rear fuel tank having to be dropped, Dang thing is full of fuel.
Time I buy enough containers to put all that fuel in.....I might be better off to dump it on the ground................HELLo........EPA
