20" or 18" wheels for Towing
This has not been my experience. In fact the exact opposite I've found to be true. The more sidewall you have the more psi you need otherwise the tire will feel 'wobbly' under high weights. And weight ratings are given as far as I know at 80psi regardless of sidewall size.
So more sidewall might be more comfy but imo doesn't ride better, especially loaded up. The higher sidewall tire exhibits more 'tire roll' which to me is a worse ride.
This is my experience switching it up nearly daily between my '11 with 295/60/20's and my '03 with 265/75/16's.
Your sidewall height difference between those two tire sizes is less than 1". You must have a highly calibrated butt meter.
As far as max psi and weight ratings...that is determined by the manufacturer. My E rated Toyo RTs have a max weight rating of 3860 lbs at 65 psi.
Either way...I think we are talking about something that is subjective when it comes to ride quality. I agree with you on running lower psi when unloaded.
Yah at current tread levels a solid inch of difference in sidewall and 2.5-3" in width. Obviously different tires/trucks and no matter what rubber was wrapped on either one the '11 is going to be more comfy. Even though the '03 is in fantastic condition and highly maintained. I've been towing heavy with Ford 1tons for over 20 years now and the 20's for just the last year. The lower profile and way wider tire handle while towing way better than anything I've previously had on a 1ton. The ride loaded or empty isn't harsh and I feel much less tire roll than I do on my '03. No one would need that sensitive of a butt to feel the difference between the two tires.
Also I've been running e-rated tires just as long and I've never owned one that has its max rating at less than 80psi but I've never had many huge tires either. Those are some real nice looking treads you have I looked them up.
It's true. Nitpicking 18's or 20's to death is pointless. Get the ones you want knowing that 20"s will have slightly more expensive rubber. Your choice in tire brand, style, and size along with how you set them up psi wise are going to have a lot more to do with ride/handling than the size of the hole in the middle.
Although, once taken off pavement, sidewall will play a larger role.
I recommend anyone here to read the Carli Suspension threads over at powerstroke.org to see what they have found through extensive testing.
I would imagine it would with stock tires, but I can't say for sure. I haven't tried it yet with the 37, but I have heard of other people getting them under there with a 37" tall tire.
I challenge you to drive an '11 truck that has 18s on it back to back with your truck. If you don't notice a difference, then your point is proven, but some of us will and do. Maybe my "meter" is calibrated better due to years in the automotive business comparing different vehicles and setups. Or because I still drive different vehicles all the time.
But I will give you this, seems your butt is more sensitive than mine. . Just razzing ya man.
I'll agree comparing all these different trucks and tires and sizes is purely subjective. The only correct answer I see is the one I knew all along. My truck is setup perfectly.........for me.
My xl has the 17" alloys. I leave my tires inflated to fords recommendations, which is I believe 75 in the front, and 80 rear. My truck still rides very good empty, especially for a 3/4 ton 4x4 in my opinion. Granted, I am lucky enough to live in a state with some of the best roads in the nation. I can't see you not being able to drop the air pressure in the 20's to get a satisfactory ride. How often are you going to have to worry with inflating your tires to run a max load?
I have a set of those alloys new never mounted that were meant as winter rims for my truck. Previous owner bought them and included them in the sale. I parked my rig last winter but if I ever winter drive it that's what will be getting mounted up and then I'd really be able to tell the difference. I have no doubt it's cushier, but for me that's not the most important. I like to throw my truck through some corners now and then too. I've been flamed on here before for saying it, but that doesn't change my opinion on it. The truck handles great with big lowish profile tires.
Well I won't hold my breath on finding a 11+ truck with essentially 18" 35"x12.50s on it that I can drive back to back with my '11.
clv
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
09-20-2018 09:29 AM
Lane Dexter
10-08-2004 11:45 AM
