Ball valves on Coolant Filter?
So I got a coolant filter for my Scursion, got it installed and noticed a leak out of one of the hoses that threads in to the block of the coolant filter. After tightening it down and re- tefloning it, it still had a small leak. Checked on it last night, as I am heading across country Thurs and noticed the pressure clamp had come loose and the hose was basically falling off. So I turned off the ball valve (which promptly broke as well) and then hose clamped the hose on (At least I fixed the leak!)
Question is, what size is that ball valve that generally goes on there? I cant take this on off and take it in to the store with me to match it up because I need to drive the truck!
I know pics or it didn't happen
Here's the pressure fitting that fell off
And here is the lovely broken ball valve.
I dunno, and if nobody else does, you can try and contact Bob at Dieselsite and ask him.
http://www.dieselsite.com/coolantfilterballvalves.aspx
Stewart
Stewart
Got mine off Amazon and they fit. I have yet to put my filter and parts in the truck to see if they can handle the job.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Tim M
Tim M
Only problem will be finding those cut off valves. I toured with modifying things s bit and then, thankfully, I remembered how well that usually DOESN'T work.
Tim M
Tim M
3000gtman
01-28-2017 10:27 PM
DawnPatrol
01-03-2015 08:38 AM
Dyllan78
06-06-2010 11:13 PM
02GrayPowerStroke
03-24-2010 02:08 PM
