1999 powerstroke clutch noise - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-26-2016, 01:18 AM
53fordman1 53fordman1 is offline
53fordman1 is starting off with a positive reputation.
I have a 1999 f-350 power stroke 4x4. The clutch does not slip at all but when I am winding the gears out say pulling a heavy load or just getting up to speed the clutch pedal stays on the floor when I push it to change gears. Also when I get up to high rpms it sounds like something is knocking in the clutch like a bad bearing but if I put just a slight bit of pressure on the clutch pedal it quiets down. It will also knock when idling in neutral but again if I put slight pressure on clutch pedal it goes away. My question is do I need to replace clutch? Every other vehicle I've had that the clutch was bad in they would slip. Thanks
Clutch rattle 53fordman1 1999 - 2003 7.3L Power Stroke Diesel 2 07-28-2016 01:01 AM
95 f150 clutch issues green_95 1987 - 1996 F150 & Larger F-Series Trucks 0 08-20-2015 08:15 PM
Clutch/Throw out noise 1997F350CCLB 1994.5 - 1997 7.3L Power Stroke Diesel 4 03-25-2014 01:47 AM
Clutch?? marks500 1994.5 - 1997 7.3L Power Stroke Diesel 43 01-23-2011 10:13 PM
ZF-5 speed 1987 F350 clutch linkage/clutch fork? Tony G Clutch, Transmission, Differential, Axle & Transfer Case 0 07-15-2004 02:35 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
