96 Crew Cab Driver rear door lock stuck down and locked
My 96 F-350 Crew Cab driver rear door lock is stuck in the locked position.
I don't have a cause but do now notice that the pass door lock will not operate with the lock/unlock switch. The rear solenoids seem dead. Front door locks are working.
I tried to put a 10-32 coupling nut on the lock riser and pull. The down position is now 1/8-1/4" higher than normal.
This thing is really stuck and is really bad.
So before I start pulling the rear seat and trying to remove the door panel from a closed door; does anyone have a idea on how I might unlock this door? It would be a lot easier to get the panel off if it is open.
Regards
Regards
