I'm having a squeak/rattle type sound coming from my front drivers side wheel (more rattle). It only happens when I go over a quick bump and happens going straight and while turning.
2012 f250. 87k miles. 4x4. I have a two inch block level (southern truck) up front.. Any ideas?
Thanks, good call. Just wanted to see if there were any common issues.
After some more driving, the sound happens more when I hit a small bump and there isn't a lot of suspension travel. When I hit a larger bump and it gets some more flex, it really isn't there. Also, it will produce the sound equally when the bump is only on the right wheel.
Thanks so far. The squeak is somewhat gone and now it's a clear, distinct rattle. I need to check the bolts on the level and all of the shock mounts still.
