Now I know why the PO sold this F'ing truck
I'm into hour 5 of trying to put the alternator and new bracket set up from L and L on. It's an alternator for gods sake WTF? The brackets don't line up, the pulley was hard as hell to change out and it's hot as hell out. I have had this truck for a week and I'm allready getting sick of it. The tech from L and L hasn't called back for any help and the directions they sent with the bracket kit suck. Welp done for today because I work a 12 hour shift tonight.
It's the big alt kit from L and L. Spoke with the guy before I ordered it and another member recommended it so I'm sure it's the right one but for some reason it isn't fitting right on my truck. The directions don't say how to bolt it on and the pictures were taken with a 1973 potato and are useless. I think the heat and the fact that I have installed 6 billion alternators in my life and this one won't go in are pissing me off. Oh and I quit smoking a month ago. lol
Sounds like a good time to start drinking
Seriously though, take a deep breath, step back, and try analyzing why it doesn't fit correctly. Is there a possibility that you don't have the motor you think you do (motor swap by PO maybe)? If the motor is correct, any aftermarket parts causing issues? Is the alternator correct for the motor? Since this is a new to you truck check all assumptions.
On my truck I had a heck of a time getting the CVF racing alternator bracket to install. I tracked my issues back to my repro water pump casting interfering with the alt bracket causing it to install at an angle. Little things like this can bite you in the *** when working on these trucks.
He told me the alt was bad and when the carb started leaking gas he had enough. I thought yeah no problem I can fix that easy. Famous last words.
I couldn't help but think of animal house quote, my advice to you is to start drinking heavily.
May I suggest that you post a photo of your bracket issues? That would help people to better understand your problem. Maybe it's as simple as fabing a spacer or the like.
Sometimes you need a little patience with these rigs, especially where a PO monkeyed with stuff. Also, especially if you put aftermarket parts on your rig. Like when I installed my headers and the durn collector was pointed straight at the shift linkage. Adapt, improvise, overcome.
Welcome to the world of "POs". You're a bona fide member now!
That's why I say "Don't be that PO" if and when ya sell your rig.
Personally, I would have tackled the alternator bracket down the road since it worked and would have move forward with fixing/correcting more pressing hacks.
True. I think I let the 90 degree heat and the frustrating instructions get to me. The truck is solid and should e a good one once I get all the bugs worked out. I think the worst thing about it is it has a really loud squeak in the cab somewhere.
