95 4x4 conversion question - Ford Truck Enthusiasts Forums
Old 07-25-2016, 12:49 PM
NotSoSporty98 NotSoSporty98 is offline
NotSoSporty98 is starting off with a positive reputation.
I'm trying to decide between putting the cab from my 95 f150 2wd on my 94 f150 4x4 or doing a 4x4 conversion on the 95. I've read in several places the TTB will bolt right up to the radius arm brackets and pivot brackets but I've also read they won't, so I'm asking anyone who's done the swap will the TTB actually bolt right up to the factory points for the I-beams or would it be easier for me to just swap the cabs?
Old 07-25-2016, 01:11 PM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
I've done it. Everything is a direct bolt-in. No fab required.
Old 07-25-2016, 07:15 PM
Quote:
Awesome thanks! Even the radius arm brackets are in the same spot?
And do you have any tips? I hope to have the d44 in this weekend and once I find a good rear drive shaft put the transmission and t case in
Old 07-31-2016, 10:18 PM
southernB Trucken southernB Trucken is offline
southernB Trucken is starting off with a positive reputation.
I'm new on here but I need help I got a 1991 f350 singal cab dually 2wd stripped chassie 10ft bed with the 7.5l aan a c4 aod automatic I believe in it and I bought it as a boom truck with no transmission in it and now I removed boom and utility body and all lines and gas tanks and it has the Dana 70 in the rear and I have a 94 Bronco that was wroled in an accident and all is good on it has a 351w and a aod trans I took them out and I want to put the ttb setup under my f350 but it's 5 lug so will it fit and could I change the axles in it to 8 lug and I have a 7.3 turbo and an s92 c6 transmission for it and I'm gonna put a flat bed on it and I'm not shure if the rear would work so same problem but bigger truck and the bronco is a d50 I believe
Old 07-31-2016, 11:31 PM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Methanoholic
Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.
Quote:
Hi southernB Trucken, Welcome to FTE!
You would be better served to start your own thread.
-Enjoy
fh : )_~
Old 07-31-2016, 11:47 PM
2wd to ttb need help
Old 08-01-2016, 12:05 AM
bbf385's Avatar
bbf385 bbf385 is offline
bbf385 has a good reputation on FTE.bbf385 has a good reputation on FTE.
I'm new on here, but...
Yikes, man!! You need your own thread and a plan. I'm not entirely sure what you want to do, but the bronco has a D44 and the trans from the Bronco will not fit a 460 or a diesel.
I don't believe the D44 TTB will fit in place of the 1 ton TIB.
Old 08-01-2016, 12:19 AM
Methanoholic
southernB Trucken, Click here 1987 - 1996 F150 & Larger F-Series Trucks and in the upper left corner you will see a button, Click on it, enter your thread Title, then enter your thread message.
When done typing your thread message, scroll down and you will see two buttons, Preview Post and Submit New Thread ... Select Preview post, reread your message and if it's what you want select Submit New Thread.
-Enjoy
fh : )_~
TTB Swap chrisfp178 1987 - 1996 F150 & Larger F-Series Trucks 4 01-31-2017 07:39 AM
2wd to 4x4 TTB swap potential? BlueOvalBud Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 22 12-15-2010 08:14 PM
95 f250 psd shackle reversal question tlee78f100 1987 - 1996 F150 & Larger F-Series Trucks 7 06-02-2010 10:09 AM
How to lengthen/modify your TTB axle housings??? atomicjoe23 Ranger & B-Series 2 10-09-2008 01:00 AM
Big tires with TTB billy87 Brakes, Steering, Suspension, Tires, & Wheels 4 07-17-2004 04:50 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
