1948 Ford front spindle bearing???
https://www.google.com/search?q=1954...wSDccMqtFfM%3A
Where it says related images, click on the 2nd from left, top images.
As you can see in the pic [...]
87907-S8 (8 not shown in pic) is the right Zerk (lubrication) fitting, 87922-S8 is the left Zerk fitting.
Since there's no specs listed in the catalog, these are a press fit into the spindle holes.
GREEN SALES CO. in Cincinnati OH (800-543-4959) has 1,209 87908-S8 & 9 87922-S8
I very much enjoy your posts, and you're right more than 99% of the time - But, this time i beg to differ.
87908-S8 1/4-28 : 11/16 long : 15/64" thread length
: type 2 (straight)
87922-S8 1/4-28 : 31/32 long : 15/64" thread length
: type 3 (45 degree)
Bottom left, page 4
Ford Standard and Utility Parts, May 1954, Form 3733
Two points for me?
Liebherr cranes have a similar set up for there thrust bearings. Also a equally nondescript illustrated parts brake down. After some Q&A with tech support and field reps one suggested to measure the inside diameter of the "top" and "bottom". The larger of the two openings would be installed towards the Zerk. Idea being the overflow from the greased stub pin would flow into the thrust bearing.
PPrash
1999 to 2016 Super Duty
08-10-2010 08:52 AM
Billyclub
17
08-28-2009 01:31 AM
Dstosh
01-26-2009 06:40 PM
