1948 Ford front spindle bearing???
Old 07-25-2016, 12:33 PM
pezsox's Avatar
pezsox
pezsox is offline
can you tell me if the bearing on the spindle on the fronts should be installed with the "seam" up or down?
also..
1. do these get bearings get greased? and recommendations on brand if so?
2. if I need to tap the threaded holes for the zerks how is that done to the taper? is there a common size for that? thanks
Old 07-25-2016, 01:47 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
What are you working on, an F1?
Old 07-25-2016, 01:48 PM
pezsox's Avatar
pezsox
pezsox is offline
yes it is an F1
Old 07-25-2016, 01:58 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Here's a couple of references; unfortunately, they don't appear to agree:
https://www.ford-trucks.com/forums/7...-question.html
https://www.ford-trucks.com/forums/5...ientation.html
Edit: one more, agrees they go open-side down: https://www.ford-trucks.com/forums/8...ml#post7789169
I don't think there's a way to grease them, which tends to give credence to the first thread's idea that they get grease from the zerk below. I just checked mine, and they are with the opening down, been in there 11,000 miles and 10 years, so it can't be too wrong.
Some Zerks are threaded 1/4-27 tapered thread, which is not exactly NPT thread. Others are straight 1/4-28 UNF. They sell little tools that remove, thread, and clean zerk holes (below), most of them are for the straight UNF thread.
Old 07-25-2016, 01:59 PM
NumberDummy
Originally Posted by pezsox
yes it is an F1
As you can see in the pic (3110), there are 4 king pin bushings (51A-3110-A - 1.30" long), are pressed into the spindles.
B-3123 are the 2 spindle bolt bearings.
87907-S8 (8 not shown in pic) is the right Zerk (lubrication) fitting, 87922-S8 is the left Zerk fitting.
Since there's no specs listed in the catalog, these are a press fit into the spindle holes.
GREEN SALES CO. in Cincinnati OH (800-543-4959) has 1,209 87908-S8 & 9 87922-S8
Old 07-25-2016, 02:12 PM
ALBUQ F-1's Avatar
ALBUQ F-1
He's asking about 3123
Old 07-25-2016, 02:15 PM
NumberDummy
I noticed that, edited the post. It's a sealed bearing, so it's not greased.
Old 07-25-2016, 02:21 PM
pezsox's Avatar
pezsox
pezsox is offline
I have the bushings pressed in already, I am wondering about part 87-922S. LMC truck had the bearings and the pins. I just can't tell which way for the bearings go.
I thought that the open side should go up for greasing purposes, but the dirt and grime thing worried me also. Damn old trucks, never any good advice!
Old 07-25-2016, 02:33 PM
NumberDummy
87922-S8 is the left side Zerk fitting.
Standard (aka hardware) parts shown in parts catalog illustrations may not have the complete part number suffix, so the standard part must be looked up under what it fits to verify the number.
Notice 87922-S8 (and 87907-S8) in the text section below the 3105-6 spindles. C = F1/F100 / D = F2/F250 / Y = F3/F350 / T = F5/F500 / TL = F4 / TH = F6/F600.
I listed the source for these 2 Zerk fittings in post #5.
Old 07-25-2016, 02:35 PM
pezsox's Avatar
pezsox
pezsox is offline
that zerk tool looks perfect. I just want them to be uniform so I can buy them all at the same time, and they all fit correctly. I believe I have different ones, jammed in there from years gone by. lol
Old 07-25-2016, 02:54 PM
pezsox's Avatar
pezsox
pezsox is offline
this helped, but still no visual.
Old 07-25-2016, 03:06 PM
pezsox's Avatar
pezsox
pezsox is offline
sorry I meant part #3123 bearing is the one in question here
Old 07-25-2016, 03:11 PM
pezsox's Avatar
pezsox
pezsox is offline
my mistake I thought you were talking about the bushings being pressed in, not the zerks. my mistake
Old 07-26-2016, 02:21 AM
big job's Avatar
big job
big job is offline
Picture two is the correct position
Old 07-26-2016, 07:19 AM
OldGrayMare's Avatar
OldGrayMare
OldGrayMare is offline
I just did mine, like Big Job said, the picture on the right is correct.
Quick Reply: 1948 Ford front spindle bearing???
