motor just quit, no idea why
Hi guys and gals. I have a 2000 ford f250 superduty 4x4 with the 7.3 in it. has 350,000 miles on it. I was driving it Saturday , no problems, pulled in to pay a bill, got back in it, it started up great, pulled on to highway went 10 yards and the motor just died- is not locked up. coasted into a BBQ place, would not start, motor is turning over. had it towed home, a buddy of mine who does work on diesels, came over for a few minutes out of his very busy schedule, tested to make sure fuel pump was working which it is. i also last month did have new injector o=rings put in too so i doubt its that. my buddy says he has another with same thing at the havy equipment place he works at, still trying to figure it out. any ideas would be healthful
Always begin where the last repair was done and work from there.
Check all fuses. You may have a short in the fuel heater or other circuit which is on the PCM/IDM Circuit.
Get a Scantool and monitor ICP while cranking. Ned 500+ psig to fire.
Check the UVCH's and #42 Pin Connector.
Air test the HPO. I'd guess an O-ring(s) or injector(s) have loosened allowing oil to escape.
You could also remove the valve covers and witness the oil while cranking. If, its leaking somewhere.
How did he test the fuel pump? Did he just listen for the pump turning on, or did he check actual fuel pressure?
Kind of a trick question- Unless you have previously installed the required adapter fittings on the fuel bowl, there is no way to check fuel pressure on a 7.3L)
You'll need these in order to hook up a pressure gauge:
1/8" NPT 90º elbow pressure port adapter.
Fuel rated Schrader valve for testing fuel pressure. Rated for Diesel or Gas.
It kind of sounds like a lack of fuel. Even if the pump is turning on, it may not be pumping enough volume to maintain a minimum of 50psi. Did the truck really just suddenly shut off, or did it sort of sputter to a stop? If it sort of sputtered or died somewhat gradually, its likely to be a fuel delivery issue. (Pump, in tank pickup clogged, filter clogged, etc..)
If it really, really was just an instant off, then its more likely to be an electrical/sensor issue, such as a failed CMP (cam sensor), or possibly ICP sensor.
I think you are well past the expected failure point for a CMP. They are cheap ( less then $20), so I would go ahead an replace it and see what happens. Worst case, its not the problem and you have a spare. Just remember, OEM Ford or International ONLY. I didn't believe it, and I spent months ( and Thou$and$) chasing a problem that 3 aftermarket sensors didn't fix and 1 oem did.
In the case of 7.3L cam sensors, no. If you do some searching there is a thread somewhere where someone bought and dissected a whole boatload of different available cam sensors for the 7.3L, and explained, in detail, the differences and wide variation in component design and manufacturing details, and why each was good or bad for performance/reliability.
True. A CMP is not going to "wear" out like a mechanical part. Over time, heat and vibration, and possible intrusion of water/salt/chemicals can kill it though; either through damage to the electronics and/or possible weakening of the magnetic field over time ( due to heat/vibration).
In any case, I was simply pointing out that the odds were no longer in the op's favor, as far as the cmp still working. Its not so much the mileage, or "wear". Just given these trucks propensity for fairly common cmp sensor failure, statistically speaking, having gone 200k without one, he is kind of "due" for one. Unscientifically speaking of course. Plus, its a cheap "guess".
Update: I changed out the CAM sensor first since it had been a long time since it was replaced, over 150,000 miles, but that did not help but for $30 from ford it was worth putting new one in. Pulled the ICP sensor which was full of oil - sure sign it went bad and shorted out. I then had a ICP sensor brought to me from o'reilly auto part since it was after hours for ford to be open- $170 dollars later it was back to running again. ICP i removed looked like original from FORD so i guess after 351,000 miles it went bad . I kept the old CAM sensor just in case i needed it since i doubt its bad, will buy another new one to have in case also. As a side note, a buddy who works on diesels also had another ford, had not been started in a year, lots of wires chewed on he had to fix, bought a borg werner cam sensor from o'reilly's cause his shop account is there plus its like 200 yards from his garage - put it in would not work, told him about what i read from you guys about using just international or ford only cam sensors, put one in, fired right up
