77 F150 NP 205 transfer case leaks
So my transfer case has some leaks, looks like the front nut/washer for the idler gear and the rear access plate for such, Also it appears the rear output seal and housing gasket are leaking. My question is: For the front nut/idler gear, can I just remove the nut and put sealer under the washer and on the threads and retorque to 150 ft lbs and be fine? or is there a special procedure? also on the rear output shaft flange can I just remove the nut then slide pinion flange off and replace seal and retorque? or is it like the diffirential where a crush sleeve and rotational torque have to be set? I'm trying to reseal this thing without having to remove it from the truck.......any answers to these questions is appreciated.
Info on it. NP205 Rebuild Guide Step 7,8 ,13, 63, 74 ,77 ect...
Parts New Process NP205 Transfer Case Parts
so after reading that write up, it would appear I can just loosen the nut on the front idler bearing remove nut and washer and reseal? what seals fluid from coming out at the washer and threads? Can I just use a silicon sealer? Also can I just remove the rear output shaft as an assembly and reseal on a bench as they do and pop back in place? I'm trying not to remove the transfer case from the vehicle.
okay, cool,I guess I'll find out.......worst case, I'll end up pulling t-case, don't want to but to get to the top bolts I'll have to pull up the carpet.
I have heard good thing about TQ king and these folks. Offroad Design - Complete Rebuilt NP205, NP203 transfer Cases
Pull the carpet, to get to the hump cover off, to get to the xfer case? You better double ck that you can get to it from up top, it might tbe further back?
before I had read this post I had pulled it this morning with adapter still on and I was going to say that thing is one heavy *****............but you beat me to the punch...lol.....so now begins the reseal, wouldn't mind using"torque king" but Montana is to far for quick standard shipping......gotta be a place closer to MD where I'm at. oh and I didn't have to slide /move the crossmember at all.
roland13
6.7L Power Stroke Diesel
02-10-2018 09:59 AM
BigSexy78
06-15-2017 09:05 AM
sbishop
03-08-2004 06:14 PM
