1953 f250 Where can I buy new spindles?
Old 08-20-2016, 06:11 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
If the cylinder bore can be honed and and inside diameter stay within limits it would probably be fine. Put a rebuild kit in it. Excessive pitting and wear would preclude this. You'll want the Ford Shop manual to go through the procedure and determine if it's good.
Old 08-20-2016, 06:43 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
It's the single most important part of the brake system, and it will be near impossible to get the reservoir truly clean. For the $50 - $60 for a new one I would toss it.
Old 08-21-2016, 08:52 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
I agree with Ross, get a new master cylinder.
On your other question, I don't think you will need or want a power booster with otherwise stock drum brakes.
Mike the Mechanic #2
10-01-2011 08:39 AM
canadian_diesel1964
12-19-2010 09:41 PM
enikolich
05-17-2010 06:21 PM
f250red
04-03-2010 01:10 PM
DR JOE
02-21-2008 12:30 PM
Quick Reply: 1953 f250 Where can I buy new spindles?
