Ford Tri Power ID help and Value
I found this Tri Power setup in S truck I bought recently. I didn't see any I'd numbers other than firing order on it. It had 3 Holly carbs on it. Anybody tell me what motor it's for and where to find I'd numbers and also what is the value
Motor it had come off.
DR is correct ,FE motor. These were used in the early 60's on 406 and 390 engines. The one you have appears to be OEM Ford. The good part is that you have a complete setup, fuel log , linkage, etc. It could have considerable value.Check around and see what they are selling for. A very good find.
A quick look on e-bay, search ford tripower, I think you'll be surprised.
Here's some more info:
Ford 6V Carburetion Technical Information
Casting numbers won't ID a Ford engine. The only really accurate way to ID is measure the bore and stroke. Exception is the 427, look on the side of the block, just above the oil pan. There will be three cross bolts for the main bearings on both sides.
Tri-Power (Ford: 6V) intake manifold/carbs could be from a 1962/63 Thunderbird 390, also available at the parts counter for 1962/64 Galaxie/Mercury 390; 406 (1962/63) or 427 (1963/64).
This set-up was standard equipment on 1962/63 Thunderbird Sports Roadsters, VIN engine code M
1958/64 FE engines have rounded valve covers without holes for oil caps, smog valves. Have an engine oil fill tube on the right front side of the intake manifold.
btw: Since the engine has an alternator, it's probably from a 1963 Thunderbird, as this was the first FoMoCo vehicle to come with them as standard equipment.
1965 was the first year that all other FoMoCo vehicles came with alternators as standard equipment.
IS THE THERMO HOUSING ON THE WRONG END OF THE MANIFOLD? DITTO DIZZY HOLE. OR AM I VIEWING FROM THE WRONG END. FLOAT BOWLS AND CHOKE PLATES FACING THE REAR. IS THIS A T BIRD THING. MARINISED. ELEVATION FRONT CARB IS LOWER THAN REAR. CARB LINKAGE CROSSES OVER IN FRONT OF CARBS.
Here's another picture of a stock setup.
