Ford Tri Power ID help and Value
Old 07-26-2016, 09:44 AM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
Originally Posted by kj1556
If I want to sell this engine and intake setup how should I advertise it? Not knowing exactly what engine it is and what year it is for sure. I would like to sell it but do not want to misrepresent what I'm selling either. Any help would be appreciated by me
I would sell the intake set up separate from the engine. The engine won't do anything to increase the intake's value.
I would pull the heads, see what engine I've got and go from there. At most I would expect to sell the engine for core value, not much more. 352/360s aren't worth much, 390/410s a little more, a standard bore 406/428 could be worth a decent amount and a 427 can be worth serious money.
Old 07-26-2016, 10:08 AM
kj1556's Avatar
kj1556
kj1556 is offline
When I pull the heads will I be looking for ID numbers or need to measure the cylinders to tell the size.
Old 07-26-2016, 11:05 AM
mikeo0o0o0's Avatar
mikeo0o0o0
You'll need to measure the bore and stroke to tell what engine you have.
4.00" bore X 3.50" stroke = 352
4.05" bore X 3.50" stroke = 360
4.05" bore X 3.784" stroke = 390
4.130" bore X 3.784" stroke = 406
4.05" bore X3.98" stroke = 410
4.230 bore X 3.784" stroke = 427 (plus cross bolted #2, 3 & 4 main bearing caps)
4.130 bore X 3.98" stroke =428
Old 07-26-2016, 01:23 PM
kj1556's Avatar
kj1556
kj1556 is offline
I believe it's a 406, What would be a fair price for motor and heads without intake.
Old 07-26-2016, 02:41 PM
greentruck72's Avatar
greentruck72
greentruck72 is offline
$1000 if in good shape maybe more. i think its funny i've been researching tri-power for two days now and looking a your pictures finally answered my questions. cool set up
Old 07-26-2016, 02:42 PM
greentruck72
another way to check if its a 406 would be to see if it has cross bolted mains, not all of the 406s had them but some did irrc.
Old 07-27-2016, 12:07 AM
thrifty's Avatar
thrifty
thrifty is offline
Do you have the old intake gaskets? Did they match exactly on the block/intake? I have the 406 version
Mr. Nasty
11-13-2016 06:14 AM
kj1556
21
08-29-2016 07:58 PM
larry69chevelle
11-08-2010 09:49 AM
masterbeavis
13
11-17-2008 09:24 PM
Ratsmoker
12-04-2001 12:55 AM
Quick Reply: Ford Tri Power ID help and Value
