Air conditioner intermittently goes HOT
Thanx projectSHO89. I'm posting for my cuz with no computer. He said this occurs cruising so don't think it's blend door. He's gonna check vacuum lines.
Does the hot water valve close when in AC mode or is hot water in heater core all time?
You didn't specifically identify the vehicle in question, so we don't even know if it has a "hot water valve". Vehicles with a factory coolant valve shut the valve ONLY when in MAX AC.
In any event, it would not cause the outlet temps to go HOT, only 1) a loss of control of the temperature blend door or 2) a combination of hot coolant flow through the core combined with a drop-out of the compressor will cause that particular symptom.
a shot in the dark, my 05 6.0 F350 did this to me when I first bought it, the air gap for the ac clutch was too wide, truck had 230K on the odometer, so it had cycled a few times. I used a thin stick to "touch" the clutch while is was running and not cooling. The clutch picked and worked like it should until it cycled off like it should. it would not pick sometimes, I pulled the bolt from the center of the clutch, removed a shim or 2(closed the air gap), put it back together, in 15 mins all was well, cost $0.00 still running that way today 54 years and 50K later.
It is NOT a vacuum problem, see my previous post. It's a blend door problem and that is electrical.
If the blend door responds to the temperature control almost all the time, it probably isn't an issue with a broken blend door. More likely, it's an electrical intermittent in either the blend door controller or in the temperature control potentiometer. I had a similar issue three years ago with my 01 SD where the temp would intermittently loos heat (it was November). I found a cracked solder joint on one of the connector pins on the blend door controller. I re-soldered it and the thing is still working correctly. I had already ordered the part in from Rock Auto which is still in a box in my garage.
That's where I'd suggest starting.
Its like the post above say's Compressor air gap issue diagnosed and repaired many of them.
Found out today it only does it in 3rd position, works fine in 2nd, he's never ran it in high. Could the faster air flow be forcing blend door open?
on
Since the blend door's function is controlling the airflow across both the heater core and the AC, if it is flopping about randomly then the temperature of air coming out the vents will be a corresponding random temperature relative to the current flop position of the broken blend door. It will usually be one extreme or another as the blend door now broken loose freely swings to either the cold or hot side. It may be a bump in the road that adjusts its position, or cornering, hence the randomness in temperature felt coming out of the vents.
on
When the blend door hinge fails the temperature will be random as the door flops around. And when I experienced this myself on my own truck, it was either hot or cold, not much in between.
