Bought the 70, comes with engine noise at no extra charge
I guess the next question should be- what year ranges can I use? I assume I could use either 240 or 300?
I found an ad for a decent, rebuilt 240 that the seller says came from a 66 mustang. It looks exactly like mine. Then there is another listing from a 65 Mustang- he didn't state the size, but the valve cover looks different (it is wavy on the drivers side side, where mine and the first one for sale is straight).
Also, how new can I go?
Grille Insert - RH or LH | Dennis Carpenter Ford Restoration Parts
I'm thinking 20-year-old previous owner + headers = drove it like a dragster until the engine complained.
The previous owner of my truck ran it lean, causing the piston to deteriorate. Also I have read the using synthetic oils, and current gas will cause all kinds of issues.
If you have good compression, why not pull the head and see what the pistons look like? Maybe you just need to replace them, instead of a rebuild.
Don't buy any used rebuilds off the internet or anywhere else.
You have good oil pressure, good compression. You say that you hear a change when you pluck wires on #5 and #6. So your problem is not in the valve train, not on the top compression ring. probably not on the rod throws or inserts.
Just drive the thing sanely until the Mystery Oil does its work.
I still think your problem is an exhaust leak. The headers make no sense at all on that engine. Sooner or later they will have to go, you know that. So pull them sooner, buy a log, have a shop resurface the mated pair, maybe replace the studs on the exhaust manifold collector, eat the repair on the exhaust system to turn it back to stock.
Got to the bottom of, well, a lot of issues. First, the crank is slightly bent at the flywheel end. Rear bearing is toast. Flywheel is cracked. #6 rod is bent and the piston has a chunk out of the side.
Not sure what this engine went through, but wow.
Found a replacement from a 66 with around 70,000 since rebuild. I've got it mostly installed now, and it sounds MUCH better. I just need to run a new exhaust, since I ditched the headers and went with the manifold that came with the new engine.
#28
#29
So now I'm having some weird electrical issues. When I first got the new motor hooked up, I had a no crank/no start. It acted like the battery was completely dead (it wasn't). After checking and rechecking everything, it dawned on me that there was no ground wire grounding the body/frame. I assume it worked before because the headers rubbing the frame in three places provided a ground path.
So I got everything properly grounded and everything worked fine for two whole days. But now all of a sudden, when I hook up the battery negative, the regulator clicks. If you hit the key, it's back to acting like a slow-crank dead battery. Release the key from the start position and it keeps trying to crank. Undo the negative to kill it, touch the negative again and it tries to (slowly) crank even with the key not in it, and a good spark flies from the negative when you touch it.
Let it sit for about an hour, and it goes back to regulator clicking, but no crank until you try- then back to a constant crank scenario until you let it sit again.
Maybe I've got my brain wrapped around the new stuff and I'm missing the obvious. But what gets me is everything worked perfect for 2 days. And it's not like there are a lot of wires on this thing.
Any ideas?
Any ideas?
