Hard starting
So it has been at the shop for 4 weeks been talking with them they are stumped. When they finish working on a car they use some of the remaining time to look at the truck. Today I was told the distributor needs to be replaced the bearings are bad in it because when idling the timing is fluctuating. Seems odd bearings on a vertical shaft should not change the timing position the center point yes but not the degrees. Lead Head if you are still out there your opinion on this please.
Delco90Custom
04-19-2019 04:54 PM
04expedition85
21
03-20-2019 07:37 AM
y2kc0wb0y
11-19-2017 04:12 PM
picklejuice52
12-06-2004 06:12 PM
