F-150 14J differential - Ford Truck Enthusiasts Forums
Old 07-23-2016, 10:50 PM
LIL LU's Avatar
LIL LU LIL LU is offline
LIL LU is starting off with a positive reputation.
I am curious why Ford used a 14J 3.00 Gear ratio on a 150 with a factory 460.
It seems to be a bit noisy and I was wondering if I should go with a 3.55 or something.fuel mileage is decent for a 460 but is long legged, yet kick down on passing tends to wind the engine pretty good. Any thoughts?
Old 07-24-2016, 10:19 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
It seems to be a bit noisy and I was wondering if I should go with a 3.55 or something. Fuel mileage is decent for a 460 but is long legged, yet kick down on passing tends to wind the engine pretty good. Any thoughts?
Original purchaser may have used the truck on the highway far more than on city streets.
14J: 14 = Ford 9" Rear Axle / 3.00-1 / 3,600 lbs. Rear Axle Capacity // J = Power Steering.
Old 07-24-2016, 12:07 PM
ultraranger's Avatar
ultraranger ultraranger is offline
ultraranger is a splendid one to beholdultraranger is a splendid one to beholdultraranger is a splendid one to beholdultraranger is a splendid one to beholdultraranger is a splendid one to beholdultraranger is a splendid one to beholdultraranger is a splendid one to behold
There's no factory 3.55 ratio for a Ford 9-inch rear end. The closest factory ratio you'll get to this is a 3.50 ratio.
There are no factory 3.73 gears for a 9-inch either. Closest 9-inch ratio to this is 3.70.
Old 07-24-2016, 05:58 PM
LIL LU's Avatar
Quote:
Originally Posted by ultraranger View Post
There's no factory 3.55 ratio for a Ford 9-inch rear end. The closest factory ratio you'll to get this is a 3.50 ratio.
Ok thanks, good to know... and I will probably just stick to the 3.00 ratio for better fuel economy.
Old 07-24-2016, 11:51 PM
LIL LU's Avatar
Thanks good info because I was not sure the significance of the J
Old 07-25-2016, 07:18 AM
DeereFord300 DeereFord300 is offline
DeereFord300 is starting off with a positive reputation.
The 3.00 gears will likely get you good mileage if your going 65 on a regular basis. If you only take it on country roads (40-50 speed limit) you can drop the gears to 3.5
Old 07-25-2016, 01:58 PM
LIL LU's Avatar
Quote:
Usually 60-65 MPH on mostly 2 lane state highways,it could use a little better take off in heavier traffic when pulling onto the highway from country roads.
Old 07-25-2016, 02:02 PM
If your looking for more torque down low and you don't have one already a towing cam may be a good idea, you'll get more push where you need it without ruining your fuel economy. Before the cam you'll want a free flowing exhaust so you can take advantage of the power
Old 07-25-2016, 02:12 PM
Old 07-25-2016, 03:18 PM
LIL LU's Avatar
I have to reach into this differential and change some bearings, maybe gears as well , it's got that pre and post throttle whine and growl going on.
Old 07-25-2016, 06:55 PM
An E4OD automatic 4-spd overdrive transmission, a stand-alone transmission shift controller and a set of either 3.50 or 3.70:1 rear end gears would give to you the best of both worlds.
Lower gearing for better in town acceleration or pulling a heavy load or, an overdrive gear for cruising the highway to keep the engine RPMs in check.
Final drive equivalent, in overdrive with a 3.50:1 rear end ratio, would equate to having a 2.49:1 ratio ring and pinion in the rear end.
With 3.70 rear end gears and in overdrive, the final drive equivalent would be 2.63:1. --both of which are even higher ratios than what you currently have with the 3.00:1 ratio.
(final drive equivalent is figured by multiplying the high gear/overdrive ratio by the rear end ratio). The E4OD overdrive ratio is .71:1.
E40D Transmission Swap - Custom Classic Trucks Magazine
Old 07-27-2016, 05:21 AM
LIL LU's Avatar
Ultra Ranger, this is an interesting read, that would be a perfect set up for someone who travels long distances or uses their truck a lot. Its worth looking into.
Looking for Vacuum Line Routing Diagram and I have the Calibration Code FrankGRUN 1968-2013 Full Size Vans 13 07-11-2016 11:02 PM
ford 302 serial numbers Terry J Hall Sr. 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2014 05:08 PM
Door tag confusion!! Vegasw0lf 1973 - 1979 F-100 & Larger F-Series Trucks 8 08-01-2013 07:17 AM
Got my Anniversary gifts today! mudder460 Arkansas Chapter 5 05-04-2011 04:29 AM
460 A and 460 J fatherford Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 03-10-2002 05:58 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
