Spray liner
"It will cost $445.00 plus tax to Line-X your 2017 F 250 with Standard Line-X. Give me a call @ 765 361-9999 if you have any questions or to schedule an appointment.
Thanks Jon
Line-X of Crawfordsville"
Originally Posted by EightySecond
Not necessarily, this is a quote from the Line-X dealer down by Indy on an 8' bed. I would compare their base liner to the Tough Bed I guess.
Thanks Jon
Thanks Jon
Thanks Jon
Thanks Jon
I too have had several trucks with spray in liners...Rhino, Line-X, Speedliner (I think that is the name). What I have found is that the quality of the liner and the thickness is primarily determined by who did the installation. One Line-x dealer can spray it thicker than another one. No guarantee that it will be the same from dealer to dealer. The chemical and property differences between the spray in liners is not as determining as the installation. Didn't sand the bed enough? Contaminate the bed? Spray less product to save on material? These concerns I found had the greatest impact on how well the liner lasted and performed. And while I like Line-x the best it is expensive here in the northeast especially if you want their top spray in liner. The factory Ford liner is cheaper and from the one's I have seen ('16's) the thickness was pretty good and even. Some installers will build up the thickness at the edges to give you the impression that they sprayed it heavy and also cheat on the sides of the bed where they spray it thinner.
I have had a Line-X liner in my 09 F150 from the day it was picked up at the dealer. I had the Ford dealer do all the arrangements and I feel I got a better price and instal this way. I still like the liner.
When I looked at the 16 F150 ford spray in liners I noticed that the very bottom of the inside tailgate did not have any material on it. If you lower the tailgate and look at area adjacent to the bed there is an area without protection. To me it looks like a good way to have some paint removed as you slide irregular shaped objects out of the bed. My Line-X is sprayed compleatly under the tailgate.
