starter question
07-22-2016, 10:12 PM
starter question
I think it should but will the starter off a 2000 work on a 2003?
I know they show different part numbers when u look them up but i think u can interchange them.
07-22-2016, 11:42 PM
Quote:
Originally Posted by
carltonwebb
IIREC (??), they are revers compatible only as the 03 has a 3 bolt pattern and the 00 has a two bolt pattern.
07-22-2016, 11:56 PM
on
pirschwagon
oopsy 03 is 2 bolt and 00 is 3 bolt Ive put a 2 bolt in a 99 cause no 3 bolt on shelf.
07-23-2016, 09:38 AM
163junk
And there is your answer.
Thanks for the correction. I'll put it in my Brain. But, as most things in there, they're dust covered.
07-23-2016, 09:46 AM
I knew it was something like that but the dust had covered mine as well. It was a 3 bolt starter.
I was not doing the work but was giving an old one to someone who needed it for an 03
07-23-2016, 01:48 PM
All are interchangeable.
I have a three bolt starter on my two bolt truck now.
03-11-2020, 10:44 AM
Badboy4wd
10-16-2016 11:16 AM
tbirdage
10-19-2014 10:40 PM
Jordan Septo
16
11-15-2007 07:53 PM
aznative981
Bronco II
05-04-2005 08:23 PM
