Ford truck bed bolt lengths
So I replaced my fuel pump last week and decided removing the bed would be the best option given the age of the truck. It is a 99 f-250 super duty. Anyway, I busted two of the bolt heads off while getting the bed free so I bought some new ones at the local parts store. The guy at the counter matched the bolts with my truck. When I got home I noticed that the old bolts had two bolts out of 6 that were shorter than the others. The new bolts are all the same size across the board. My question is should I take the bolts back and search for the shorter bolts or will the the new bolts be compatible?
Hopefully someone has had the same issue and has a resolution.
Being as candid as possible, this truck is a pain in the rear to get parts for. From what I understand they changed some hardware half way through 99 so parts manuals continually give me the wrong part. Any help or input would be greatly appreciated.
Thank you
-Nicl
Thank you
-Nicl
jumbaco
15
06-29-2013 06:11 PM
thesaintnr1
06-20-2011 12:16 AM
quaddriver
12-09-2008 11:58 AM
