a/c still not cooling the cab ????
Old 07-26-2016, 03:37 PM
trevorrules's Avatar
trevorrules
trevorrules is offline
I'll have to get another one but it seems to get cool when I'm going down the road if I stop and just let it idle it doesn't blow as cold
Old 07-27-2016, 08:59 AM
Lead Head's Avatar
Lead Head
Lead Head is offline
That is normal on a vehicle equipped with a mechanical clutch fan. There isn't a lot of air flowing over the condenser at idle.
Old 07-27-2016, 03:54 PM
trevorrules
Ok that makes sense , but I added another small can for kicks and giggles , and it blows really cold and I also noticed last night I was pulling a suburban so I cut the fan off and as soon as I did that hot air was coming through the floor vent and some was coming out of the vents
Old 07-27-2016, 03:57 PM
Lead Head's Avatar
Lead Head
Sounds like you have a blend door issue then, if you are getting hot air coming out of the vents?
Old 07-28-2016, 06:53 AM
Krisverde's Avatar
Krisverde
Krisverde is offline
Check blend door and also check temps at vent @ high idle. 2k rpm roughly.
Old 08-05-2016, 10:50 PM
trevorrules
Sorry for the late reply I got caught in some stuff but the max a/c does not work , it makes this hissing sound when ever I turn it max ac but as soon as I turn it to ac the hissing stops ?
Old 08-06-2016, 08:28 AM
Lead Head's Avatar
Lead Head
The vacuum line going to the recirculate door is probably broken. Its located underhood on the firewall on the passenger side.
jgarrison31
2017+ Super Duty
42
12-08-2017 05:30 AM
Mike Parker
10-29-2015 05:47 AM
bigb56
09-13-2014 08:37 PM
Danger_Dave
21
10-04-2009 11:47 AM
yendor
Aerostar
01-11-2005 06:15 PM
Quick Reply: a/c still not cooling the cab ????
