i have a 95 pws and iv charged the a/c with the low side reading @47psi and the high side reading @ about 270psi @ around 95 degrees outside . the a/c clutch is cycling like its supposed to, condenser is sweating . the air is cold but its not cold enough to cool the cab. id say its about 60ish degrees blowing out the vents and I don tknow what else it could be that's causing it not to get cold? would anyone have any ideas????? any help would be greatly appraitede!!
Check the heat blend door to see if it not fully closing the heater air flow off.
On my 89 F250, during the summer I just bypass the heater core and that rids the heat soak from the heater core inside the AC/heat box. Doing that I get ice cubes tossed from the vents!
I would get a thermometer and stick it in the vent, I did the same thing, I recharged my system and though it wasn't blowing very cold, after sticking the thermometer in the vent and letting it sit with the AC on for about 15 minutes, it actually went down to 47*F that's pretty cold when the temp outside was a little over 80*F. Remember AC units are made to pull the humidity from the air, they are not made to be an actual refrigerator unit.
