vacuum pump questions
I don't know what the specs were on the stock set up. But, that pump lists up to 16 inches of gravity and 32 PSI. I have serious doubts the manifold produced those numbers. I do agree it would probably be best run through a reservoir. I would think 32 psi would probably be enough to damage the internals on the motor.
I don't see where that lists a pressure rating? The kind of pump needed for the wipers has to have a lot of volume. The factory-style dual diaphragm fuel pump was ideal.
got it apart and back together. Works great and pulls 18" when run off the 6V battery.
from what i can tell it has a cut out switch that is adjustable so its not running unless the vacuum drops below the set point. ill put it back in the truck sometime and see what i can do. if thats the case i can likely get by with running in on 12v because it will be running intermittently. a look at the inside windings and it was like new with stout wiring
Then perhaps a larger pump. I'm not trying to sell or push any particular pump. I chose to show that one because of the very low cost. If it's not up to the task, go bigger. My original question still stands. Could the vacuum wiper issues be resolved with an inline pump? Knowing the amount of vacuum required, would, of course, be a help. It just seems to me, an inline pump would quickly and finally resolve a lot of issues.
I'm going to see if I can locate something cheap enough to experiment with. It can't be that difficult to route the pump and my neighbor just pulled a vac reservoir from his 51 sedan, (with a chiby SB). I'm thinking putting that plastic ball between the pump and the wiper actuator would be just the ticket needed.
#29
I don't want to discourage you but I believe the small ball reservoir will not provide much help. Those reservoirs are designed to move small HVAC motors one time where the windshield wiper motor operates constantly and uses lots of air volume. I figures out about how many cubic inches the motor used but no longer have those figures. I built a 4" X 5' reservoir from PVC pipe. It seems to help some but I've not had chance to really test it. Please report back when you have a chance to test it. If you have a good steady vacuum source, these wipers can work very nicely.
#30
In all the vehicles I have had with vac wipers, I have never had one that operated well by any modern standard. Even my 53 business coupe was only 11 years old when I got it and the wipers still had the same issues then, as today.
