What make rear differential would a 2000 E350 have?
Looking at a van in a junk yard its a 2000 E350, full float axle with rear disc. I was under the impression the Econolines from 1992 and up were Dana rear ends. I found this chart that says Ford, which I believe would be a Sterling. Its axle code 39 which is 3.55 per Oasis just like this chart says. So would this be a Dana or a Sterling? My cousin is looking at it, I'm not there to see it. Thanks.
Ford Axle Code Chart - Ford-Trucks.com
It's going to be a Dana 60 or 70. 99 was the first year with rear disc brakes. Sterling was on the F series or Excursion.
Find the BOM# and that will have the specs. Dana Holding Corporation - The Expert Axle Bill of Material
You can find everything you would ever want to know about the D60 here: Dana 60 Axle Tech Article and Resource Directory
Are there 10 bolts or 11 holding the diff cover onto the pumpkin? Here's a handy reference for visual inspection. Differential Identification | West Coast Differentials
I believe a Sterling would have an 8 on 170mm bolt pattern. The vans are all 8 on 165.
Jesse V
04-05-2012 09:57 PM
RustyShackelford
01-26-2011 10:14 PM
Dustin_86
12-19-2004 12:11 AM
