110 outlet question
Old 07-22-2016, 10:56 AM
Bev Jane's Avatar
Bev Jane
Bev Jane is offline
110 outlet question
I have a 2012 F-150 Platinum. I have a working canine and am installing a temperature monitoring device to alert me when the temperature inside the vehicle exceeds a safe maximum. The monitor device has a 110 plug. My truck has a 110 outlet in the super crew, but is not hot if the key is off. Is there a way to keep the 110 hot with the key off? Thanks in advance.
Old 07-22-2016, 12:12 PM
King-bRanch's Avatar
King-bRanch
King-bRanch is offline
You stated "I have a working canine"
Do u work for a PD or is this just a privately owned vehicle
If anything to do w/a PD, do NOT modify this at home, as the Department has to follow strict rules regarding K9 Vehicles.
Old 07-22-2016, 12:30 PM
Bev Jane's Avatar
Bev Jane
Bev Jane is offline
Bev Jane
Thank you. Although the son and grandson of Police Service Dogs, my boy is SAR. Yes, POV.
Old 07-22-2016, 02:47 PM
AzPete's Avatar
AzPete
AzPete is offline
I believe the 110v requires the vehicle to be running for it to produce the current. There is no way to get 110v out of the 12v battery and have any charge left as far as I know. Law enforcement around here just leaves the car idle with the ac on. The temps go up so fast, it hardly seems safe to monitor it to see if it needs to be on.
Old 07-23-2016, 07:20 AM
bakon's Avatar
bakon
bakon is offline
As a former handler and supervisor of the k-9 unit....do not trust those things. I have seen them fail.
The 110 is only hot when on and would kill the battery if wired to be on with vehicle off.
The k-9 should never be left with vehicle off....hot or cold.
Windows should always be cracked ....hot or cold
Don't know if your trying to make a building unit work for a vehicle as all vehicle units should be wired directly to battery and run off 12v.
Again DO NOT TRUST these UNITS.
Old 07-25-2016, 09:11 AM
wrvond's Avatar
wrvond
wrvond is offline
To answer your actual question - there is no easy way to keep the 110 outlet on with the ignition off. Your only real option is an after market inverter. They come in various sizes and plug into your power port. You'll want to be very careful to ensure the inverter doesn't draw more current than your 12 vcd power port can provide and that it is able to support the power requirements of whatever device you plug into it.
You may even want to consider installing a second battery (with appropriate wiring) under the hood to increase your available power.
Marcie4351
2004 - 2008 F150
01-07-2019 12:55 AM
CT15
2017+ Super Duty
03-23-2018 09:25 AM
HGI
2009 - 2014 F150
08-09-2017 12:04 PM
mikehfrye
2017+ Super Duty
01-04-2017 10:32 PM
goatdriver
2004 - 2008 F150
09-18-2008 02:54 PM
Quick Reply: 110 outlet question
