LED fogs/LED "cube" lights on the front - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-21-2016, 05:45 PM
ufvj217's Avatar
ufvj217 ufvj217 is offline
ufvj217 is a splendid one to beholdufvj217 is a splendid one to beholdufvj217 is a splendid one to beholdufvj217 is a splendid one to beholdufvj217 is a splendid one to beholdufvj217 is a splendid one to beholdufvj217 is a splendid one to behold
those that have them, or any LED lights on the front for that matter, weather they can be used with oncoming traffic or not, did you go with spot lights or floods? or both? or a single one but the "combo" ones that i guess are both built into one? i'm curious what most like better, i think the spots because they project further. i have a set of each (not installed yet) but i want a couple more for the front bumper, i'm thinking of going with the spots though.
Old 07-21-2016, 09:42 PM
eberlestock's Avatar
eberlestock eberlestock is offline
eberlestock is gaining momentum as a positive member of FTE.eberlestock is gaining momentum as a positive member of FTE.
It depends on the lights. I have some lower power floods that don't blind anybody. Beings how they are actually in a fog light position buy some "fog" leds. They should be ok. I put high power spots on my wifes jeep in place of her stock fogs. I had to aim them right at the ground in front of the jeep or they would blind somebody. Still makes for some decent light though
Old 07-21-2016, 10:01 PM
pirschwagon pirschwagon is offline
pirschwagon has a good reputation on FTE.pirschwagon has a good reputation on FTE.pirschwagon has a good reputation on FTE.
I have yet to find smaller LED's that are as luminous as Halogens for a reasonable price. While they have reduced in price. Just not enough for me to change mine out yet.
Old 07-22-2016, 12:47 AM
JoeyCap's Avatar
JoeyCap JoeyCap is offline
JoeyCap has a good reputation on FTE.JoeyCap has a good reputation on FTE.
I replaced the bulbs in my fog lights with LEDs. Since they don't have that cutoff line like headlights do they can be blinding to to oncoming traffic.
But they are extremely bright and a great flood light even in the stock housing.
Old 07-22-2016, 10:55 AM
ufvj217's Avatar
Im considering doing that too Joey. What bulbs did you go with? Pic?
Old 07-22-2016, 12:07 PM
auburngrad auburngrad is offline
auburngrad is starting off with a positive reputation.
I personally split the difference. I have driving light. I knew I didn't want spots down low. I put bars in the grill.
Mine work great. Actually work in the fog and have enough distance to help at night on the really dark country roads. But wide enough to matter through turns.
I have Rigid D2
Old 07-22-2016, 12:22 PM
Firekite's Avatar
Firekite Firekite is offline
Shining Adonis
Firekite has a great reputation on FTE.Firekite has a great reputation on FTE.Firekite has a great reputation on FTE.Firekite has a great reputation on FTE.Firekite has a great reputation on FTE.
Yeah, I'm with auburngrad. I mounted an additional pair of driving lights and just used those when I need more light (in my case any time the high beams come on), and I left my stock halogen fogs alone. You could easily do the same with LED or HID or whatever else exists out there, of course. I just used PIAA "Xtra" bright halogens, and they are great. See http://www.ford-trucks.com/forums/14...2011-f250.html
Old 07-22-2016, 01:37 PM
JoeyCap's Avatar
Quote:
I have these:
9145 LED Fog light Kit | 9145 LED Upgrade
I'll try to get some pictures tonight. They're more than bright enough to drive at night without the headlights. I don't do that, they're just that bright.
Old 07-22-2016, 11:33 PM
DallasSuperCrew's Avatar
DallasSuperCrew DallasSuperCrew is offline
DallasSuperCrew is starting off with a positive reputation.
Old 07-31-2016, 01:57 AM
thzpcs thzpcs is offline
thzpcs is gaining momentum as a positive member of FTE.
I got a set of these, they work pretty well.
Old 07-31-2016, 07:49 PM
JeepPuller's Avatar
JeepPuller JeepPuller is offline
JeepPuller is starting off with a positive reputation.
Quote:
Originally Posted by DallasSuperCrew View Post
Hey DallasSuperCrew,
Do I understand your link correctly in that you simply replace the fog light bulbs with the ones listed? They appear noticeably brighter. Are they a problem when driving at night? Meaning, do they blind oncoming traffic?
Old 08-07-2016, 01:49 AM
ufvj217's Avatar
after i finish installing my new front bumper (bumper in these pics is my old one), i'm gonna mess around with mounting this bracket and see how i like it. not sure if i will or will not use it, but it's been sitting in my closet for years.
what do you guys think? it's a rally type light bar for my 04 Mini Cooper, but i'm never going to use it on there. i don't think it looks too bad on here, gotta see how it looks with the LED cube lights installed on it. i think if i can mount it somewhat stealthy looking, it may work out good.
also, the stock fogs are removed and won't be going back in, as i have a front hitch receiver i'm installing, and the particular one i have doesn't allow the fogs to be remounted in the bumper. if i end up using this, ill probably do all 4 spots, but also want to first see how the center 2 mounts look at night with spot cube LEDs, and the outside 2 mounts with flood cubes, slightly angled to either side. i think that combo may work nicely. will def keep you guys updated. been lazy lately, bumper just needs the brackets bolted to it adjusted slightly (just loosen the bolts, adjust then re-tighten) then bolt the hitch and bumper on and ill be done. then i can mess with positioning this light bar.
i want to do a light bar above the windshield also. those with them, flat vs curved...pros/cons? and i think those they have the flood/spot combos like i believe was stated earlier in this thread IIRC.
Old 08-07-2016, 04:00 AM
Firekite's Avatar
Shining Adonis
Be prepared to light up your hood.
Old 08-07-2016, 08:08 AM
Doc Foster Doc Foster is offline
Doc Foster is starting off with a positive reputation.
Quote:
How much brighter are they?
Are they too bright to use in traffic?
Old 08-07-2016, 11:04 PM
Yes Sir. They arrived in 3 days, and I put them in that evening. Haven't been flashed yet. Output is good. I love 6000K's and wanna get these with V-LED's to match the color:
SpyderŪ - Ford F-250 2011-2016 Chrome Halo Projector LED Headlights
LED interior light conversion with theater dimming?? AGrayson84 1997-2006 Expedition & Navigator 1 10-20-2016 04:15 PM
Cool LED Truck bed lights carid Vendor Specials, Discounts, Product Announcements & Group Buys 2 12-22-2015 07:37 AM
Changing to led ALAN_50501 Aftermarket Products 2 09-27-2015 10:13 PM
LED light Bar ? big-head Aftermarket Products 9 09-21-2015 01:42 PM
LED light Bar big-head Offroad & 4x4 2 06-20-2015 10:20 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
