Tire fell off while driving - Update
Went to Lowes today and on the way home I felt the rear of the truck lift up, like the whole rear axle was being ripped off, and looked back to see the spare tire rolling across the road. Happily I was just leaving the parking lot but it was a jarring experience. The stationary bolt let go:
You can see where there was apparently a crack as there is only a sliver of silver metal. The rack was dragging behind the truck by the end that normally drops down, held on by a padlock.
I picked up what hardware I could find. The tire sheared off two of the bolts holding the bumper on when it lifted the truck up:
Just a bit of scratched paint where the bumper was wrenched up:
All I can say is I must be living right because this would have been much more serious at freeway speeds. I'll go ahead and take the bumper off, repaint it and, before I reattach it, secure the spare with new bolts AND a cable.
At least the wheel on the rear end didn't come off the truck --been there, done that while I was slowing down from 60 MPH to about 45. When the left rear wheel came off, it rolled the left rear quarter panel wheel opening on my '68 Mustang. After that incident, the wheel opening on my Mustang had more of the appearance of a '57 Chevy.
Get some grade-8 bolts, washers and nuts for the bumper --maybe even for the spare tire rack as well and anti-seize the threads before you torque them down.
on
Had the left rear tire come off a 53 Chevy 1 ton I was working on. Took it out of the shop and down the street. Tire fell off half way down the block and rolled up to a neighbors front porch.
All 8 lug nuts had spun off. I picked them up 1 by 1 down the street. Luckily it did no damage to the bed or fender. Just dropped down on the drum.
Still don't know how all those nuts got loose....
Again, it could have happened while we were up on that mountain and cast us down the side. Guess I'm lucky.
Anyway, I think that, because the bolt was fixed rigidly to the frame, the spare fatigued it by the natural rocking back and forth that happened when I drove the truck. In other words, I think that bolt was loose for a reason: so it could give a little and 'hold on loosely', as 38 Special put it.
What do you all think? How are the bolts done on your trucks, tight or loose?
Yeah. Here's the thing: I think this is my fault. The spare was hanging a little loose from that bolt. It wasn't tightened up to the frame and it was shifting and rattling, so I tightened it. This is the forward bolt, the opposite of the one you twist to drop the spare.
Every once in a while (usually while killing time) I'll do a bumper to bumper hardware check.. a preflight if you will. Vehicles that ride "hard" tend to loosen up like my former street-legal autocrosser... the suspension was really stiff like these trucks and hardware always loosened up and needed attention.
Tire , brake drum& axle
In 1965 I was towing a 56 F 100 with our wrecker when the everything came out. At least it did not hit anything or anyone.
I had to balance the tire on an angle and wrap a rag around the axle so I could roll it about a block. Then heave it into the back of the truck bed. Then go against traffic with the wrecker to pick up the rear of the truck.
I miss those days. NOT!
