05 F150 5.4 (lost drive & overdrive)
I have lost drive and overdrive. I have first and second and when I let off the gas pedal everything seems normal. When I am in drive with overdrive switched off and keep a steady speed it doesn't shift into drive. When I let off the gas in drive the tach goes to 1k and its like I'm in neutral. If I switch OD on it's like neutral and the engine revs. I have pulled the pan and valve body and do not see any metal. OD snap ring is intact. Fluid looks good with no burnt smell...I'm thinking shifting solenoids but have not tested them yet. There is no grinding noise at all and no slipping in first and second gears.
It threw cam sensors codes and I replaced both but I think that was from the neutral condition and test drove before dropping the pans and still no shifting to drive or OD.
No transmission codes
Regards,
Robert
Regards,
Robert
if you have drive with your overdrive off it possible one of these 2 is the problem.
Servo piston ring that broke and makes the piston drop to far that the oil cant activate your OD and can be done from oil pan
OD band can be replaced fairly easy.
when you open the tranny its the first part coming out al other gear and clutch stays in casing.
HOPE this Help if you need any pics of what it looks i can provide them for you
the clip is 7$ CaD then band is somewhere in the 40 to 80 depending where you go summit racing does have some perfomance
