Strange instrument cluster issues. - Ford Truck Enthusiasts Forums
Old 07-21-2016, 01:04 PM
Old Primer Red Old Primer Red is offline
Old Primer Red is starting off with a positive reputation.
Ok, I recentry upgraded my 95 F150 ip cluster to one with a tachometer. I actually found a cluster from ano there 95, so there isn't an issue with the charging system. I did this last week, and I also changed all the clusterm lights to LEDS (by the way not just any 194 LEDS will work, but that's another story). When I put it back together, everything worked gage wise, but yesterday when I got in the truck the voltage gage was pegged to the left, and then slowly crept back towards the middle throughout the drive home. I've never seen anything like this. How about you guys?
Old 07-21-2016, 01:55 PM
Lead Head Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
It's possible the donor cluster's volt meter was faulty. Did it only do it once, or does it do it consistently?
Old 07-21-2016, 02:17 PM
It started yesterday. I installed it last week on Wednesday and it was working fine. It did it again today on the way to work.
Old 07-21-2016, 02:21 PM
You might want to check to to verify the alternator is properly charging.
Old 07-25-2016, 08:59 PM
Finally figured it out. The needle is dragging. Not sure if I want to tear back into it right now, I just replaced the big black bezel with the vents and the two trim pieces attached and don't want to risk any damage to the new parts.
What clusters work with what years? WilliamKG88 Ranger & B-Series 1 07-30-2015 11:44 PM
Fuel gage question... CNC 1999 to 2016 Super Duty 1 06-18-2015 07:33 PM
'92-'96 instrument clusters Old Primer Red 1987 - 1996 F150 & Larger F-Series Trucks 2 11-04-2014 08:51 PM
76 F250 Charging problem Riderman 1973 - 1979 F-100 & Larger F-Series Trucks 1 07-12-2014 01:34 PM
Oil Pressure Gage & sender - resistance value? mich52 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 12-30-2003 01:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
