Help with timing 2006 5.4L Triton. Getting conflicting info!
Are the timing chains "zero tolerance" in regards to play in between each individual link? I tested the chains and I do feel a slight bit of play in the pins... the truck has 250,000kms on it approximately.
Furthermore, the paper gasket on the tensioners tore slightly. Can a small amount of RTV gasket maker be used?
The guides have noticeable wear, but no "severe grooves" or cracking.
I told my buddy here to replace everything, chains, guides, phasers, VCT solenoids... he's busy having a stroke at the moment trying to process if he needs to remortgage his house or not to pay for it all
I just noticed @EBC-150 's above comment. And I agree whole heartedly. Also, I would remove the VCT Solenoid "body" on both side and flush / clean them out very well. They have fine screens inside them that are just like the screens on VCT Solenoids. Junk / trash / old varnish chunks are death to phasers. Be as clean about everything as you possibly can.
Edit: upon second inspection the tensioner gasket might be some sort of thin rubber. The gasket is so hard and brittle it appears to be "paper-like"
The tensioner "pistons" seems to have ok resistance to it.
But as a Technician yourself, you know how hard customers can fight when it comes to paying to replace parts when they think they're still good. I told him to just "put his nose to the grindstone" and pay for the new parts. But he wants me to re-use the parts. He can't afford a proper repair. So I might be forced to "MacGyver" a solution.
@ElectroVeeDub, the tensioners rely on oil pressure to work properly, soooo...
I totally agree with you. Those parts must be replaced regardless of whether or not they're worn.
I realize that. But he doesn't want to replace the tensioners either. So I'll clean the mating surface on the heads, use a small amount of RTV gasket maker, and try to make sure theres no excess to dislodge and plug up the tensioner or fall into the oil pan below.
The thing that concerns me is the play in the chains.
I think the owner of this truck just wants it moving so he can sell it and off-load his repair bill to the next sorry SOB...
#28
#29
#30
