Check Engine Light- constant on
Old 07-20-2016, 06:27 PM
Gidg's Avatar
Gidg
Gidg is offline
I looked at mine and it looks just like yours without the gold emblem Pirate4x4. So I guess that means I have to unscrew it. It's 99 degrees here! UGH!
Old 07-20-2016, 07:35 PM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is offline
Without the gold emblem meaning it sez superchips but is not gold colored ?
Old 07-20-2016, 07:36 PM
pirate4x4_camo
How about a pic in the vehicle before you take anything apart ?
Old 07-21-2016, 06:42 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
How about getting the fault codes first. If you have a Superchips in there, you've probably got a ROM-checksum fault or something similar.
Old 07-21-2016, 04:02 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Originally Posted by Krazee Matt
As Tom said, knowing the exact code will help with this immensely. Keep in mind most part store freebie check machines won't pull every nitty gritty code
You need to have the codes read, and the parts stores in California no longer will read trouble codes for free, but even if they did, they don't have the scanners that will read the diesel related codes, so if you have a glow plug that's bad, or your Glow Plug Control Module (GPCM) is bad, your truck will still run fine, but you'll have an activated SES light all the time.
I've had a bad glow plug in the Ex for almost 4 years now that keeps my light activated.
Stewart
Old 07-21-2016, 06:40 PM
Gidg's Avatar
Gidg
Gidg is offline
OK all, thank you so much for helping me out with this! Hubs is going out to get a photo. Regarding your question about the Superchips emblem, it's not on there at all. The smog cert dude that reset my computer said I have to travel 50 miles before my computer recovers it's memory? I have no idea if that's accurate or not. I haven't driven 50 miles since he reset my fault codes in any case and my CEL has not come on again. We attached some photos of my Ex and the computer.
Old 07-21-2016, 07:22 PM
pirate4x4_camo
Yes, the computer stores a history of fault codes for 50-100 miles.
Tip, Do not exceed about 3/4 throttle for the next 50 miles or so.
If it does have an old reflashed chip they typically only tripped codes at full throttle.
Old 07-21-2016, 11:21 PM
Krazee Matt's Avatar
Krazee Matt
Krazee Matt is offline
Rhat support bracket around the computer kinda renders things difficult to see.. Just saying '
Old 07-22-2016, 10:09 AM
Gidg's Avatar
Gidg
Gidg is offline
OK thanks Pirate. 3/4 Throttle it is. But crap, I have to travel on the freeway this afternoon. So should I go super slow?
Krazee Matt, we have semi-twin Exs!
Old 07-22-2016, 10:23 AM
Krazee Matt
Semi-twin, haha! Hadn't thought of that honestly.
Old 07-22-2016, 04:31 PM
pirate4x4_camo
I only recall my light coming on under full load. Should be no problem cruising highway speeds.
Old 07-22-2016, 04:56 PM
Gidg's Avatar
Gidg
Gidg is offline
Ya, I've gone 50+ miles now and no light but then I shut it off to come back to work. So we'll see whether it comes on next time I start it. That's what happened in the past although I don't recall whether it was after 50 or 100 miles.
On a separate note, Krazee Matt mentioned some bluetooth enabled scan tools so I can get the codes myself. I have researched it on the 7.3L forum and the internet and there are so many threads but not many that deal with the BT technology. Looks like, based on reviews, that BlueDriver is their tool of choice. Do any of you have any thoughts or experience?
TopReviews.best - Best OBD2 Scanners 2016
  #28
Old 07-23-2016, 12:43 AM
Krazee Matt
Let me poke around for a few minutes, I'll find the threads I was talking about. Also if you can PM, hit up Tugly. He's a guru.
  #29
Old 07-23-2016, 12:50 AM
Krazee Matt
Tugly's (Rich) post in this one: https://www.ford-trucks.com/forums/1420317-obd-app.html
Link from Rich's signature line on OBDII devices: https://www.ford-trucks.com/forums/1...the-cheap.html
I'm running a ScanGauge myself, not as in-depth as Torque Pro or AE, but it suits my needs.
  #30
Old 07-25-2016, 07:54 PM
Gidg's Avatar
Gidg
Gidg is offline
Hey, nice cross!
And thank you!
Quick Reply: Check Engine Light- constant on
