Need truck for towing – tapping ur experience
Hello,
Well I was hoping to use the 85 F-250HD I’m restoring (a multi-year process so far) but it won’t be able to tow as heavy a Travel Trailer as I’d like.
Don’t want to spend $40,000 on the latest and greatest Ford. Looking for something 3-5 years old. Don’t need a lot of bells and whistles, the fewer power accessories the better IMO.
BUT must be reliable and a workhorse. Need to tow a trailer around 11K – 12K (maybe a bit more or less) lbs
Any recommendations of a suitable Ford Truck? Reliable, Workhorse, the fewer power accessories the better
Your experience and knowledge are appreciated
Thanks
Rgds
nonrev
Thanks
Rgds
nonrev
Look for a retired municipal truck? Something in an f250 or f350 SRW.
In our area PG&E (pacific gas and electric) or CalTrans is constantly auctioning off vehicles that are clean, well maintained, and have barely over 100k on them. Something like that would be budget friendly but reliable.
The ram has the best engine, and the transmissions are ok. The allison behind the duramax is a really beefy trans. I still like the ford as the best "truck".
There is a disadvantage in the diesel V8 design versus the more industrial i-6 of the cummins. The ram would be my choice hands down as a tow rig. That's all you see pulling multicar trailers from LA to SF. It's just cummins after cummins after cummins. Towing two or three vehicles up or down I5.
Hello,
Thanks
Rgds
nonrev
Thanks
Rgds
nonrev
P.S. Just saw your other post here https://www.ford-trucks.com/forums/1...ng-limits.html. Looks like there are some number discrepancies depending on if you are looking at factory literature or sites like Trailer Life or Camping Life.
Here's the link to his other thread: https://www.ford-trucks.com/forums/1...ng-limits.html.
The issue is his transmission and axle ratio. Ford rated a manual tranny w/a 3.55 axle at 11,500 lbs, as shown on my web site: Towing - ???Gary's Garagemahal. Now, if he had a C6 his rating would be 15,000 lbs. Or, if he had 4.10's and a manual tranny it would be 16,000 lbs. And, if he had both a C6 and 4.10's it would be 18,500 lbs.
If it were me and I liked my Bullnose I'd seriously consider swapping in a ZF5 and 4.10's. The 4.10's would give a 16,000 lb GCVWR and the ZF5 would give a serious 1st gear for starting and an overdrive for cruising w/o the trailer.
The tow ratings with a manual trans, especially with taller gear ratios, were pretty laughable back in the day. Gary's chart from the '85 owners manual shows what I remember from my '85 F-250HD, 7800 lbs with a 351, manual trans and 3.55 gears. Nobody can believe me that the GCWR was really that low, especially given that the GVWR was 8600 lbs! So I guess I could only load the truck to the 8600 lb max if I was towing a trailer that weighed negative 800 lbs?
on
My son is an ASE certified master and works for Dodge/Chrysler/Jeep/Ram Trucks as it's now called ... He says the only good Ram is one with a Cummins and that is the only good thing about them!
He drives an 07 Chevy Duramax 2500 Classic.
Personally, I have yet to see an older (new era) Ram that didn't rattle.
Maybe a city truck, but none that run the kind of roads we have here in Maine.
Sorry, I'll stick with my Fords ...
-Enjoy
fh : )_~
-Enjoy
fh : )_~
USMC1302Colt
6.2L V8
19
02-12-2019 01:10 AM
Travelchief
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
05-29-2017 04:37 PM
turnkyle
33
10-01-2012 10:33 PM
newtruck
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
06-05-2002 12:19 PM
