long cold crank no start hot
Old 07-19-2016, 04:16 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
Hydraulics shops should have the -5 ORB to 1/8" NPTF adapter for the oil gallery plug for a couple bucks. The test fitting that replaces the IPR is available from Accurate Diesel for ~$90, which seems high to me but I guess when you need it, you need it.
Old 07-19-2016, 04:34 PM
pirschwagon's Avatar
pirschwagon
pirschwagon is offline
Got this from another thread....
Alternative Hose Inc..714-414-0904 Just explain what you need. They're familiar and inexpensive.
Old 07-20-2016, 11:36 AM
sandflea1's Avatar
sandflea1
sandflea1 is offline
ran some more tests last night after getting the truck to start. the test I ran is the one where is wants you to press the brake peddle and turn the wheel. when the test finished it came back with 5 or 6 codes. all codes said short to ground. with out even thinking I shut the truck off and closed out of my scan program with out saving the live stream or the test results. so now I will have to run the test again tonight for the codes. also going to start looking at all my wires under the hood.
Old 07-20-2016, 11:54 AM
pirschwagon
If codes presented on the tool they should be stored in the PCM so long as you don't disconnect the batteries.
Old 07-20-2016, 11:44 PM
sandflea1's Avatar
sandflea1
checked volts tonight. the vpwr volt at cranking is 13.75. the vref volt is at 5.03 while cranking. hot and cold. one thing I did check before I tried to start the truck tonight was the oil reservoir and it was way low. so I'm guessing a major leak or bad hpop, waiting on the stuff to do the air test.
Old 07-21-2016, 06:57 AM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
If you can monitor these 2 items,monitor IPR% along with ICP, and do a run with it warmed up and watch what the ICP and IPR% do. Get the truck going about 40mph or so, and just roll into the throttle and hold it there till about 70 or a little better. As the IPR% goes up, so should the ICP. If the ICP starts dropping while the IPR continues to climb, you're losing oil somewhere. Most likely through injector o-rings. Who did the injectors for you, and what about the o-rings. I know it's been some time back, but there was a bunch of o-rings that were being used on some of the aftermarket injectors that did not hold up.
On edit: Is your truck tuned? And does it have factory injectors? The early 99's have a smaller HPOP, that's why I ask.
Old 07-21-2016, 11:06 AM
sandflea1's Avatar
sandflea1
the truck is tuned. running a super chip programmer. been in there since I bought the truck in 2006. I got the injectors from Pensacola fuel injection and stayed with stock application. I have not ran the test while driving the truck. I will do that tonight.
Old 07-21-2016, 11:15 AM
cleatus12r's Avatar
cleatus12r
cleatus12r is online now
Butt-Head
Received 1,972 Likes on 1,107 Posts
High pressure oil leak plain and simple. The higher viscosity of the oil when cold semi-masks the issue and once the engine starts there is sufficient flow from the high pressure oil pump to maintain operation until the engine is shut off.
I bet Pensacola doesn't use genuine Ford/International o-rings on their injectors.....makes them cheaper to eBay shoppers.
Old 07-21-2016, 11:45 AM
sandflea1's Avatar
sandflea1
here is something that I just thought of. about the time this started to happen I replaced the IPR and truck worked great. I had a leak at the HPOP. one of the fittings for the oil like going to the passenger side head. I replaced the fitting at the pump with a new one. mine is the style with the check valve in it. when I screwed the fitting in the pump I am not sure if the spring in there seated properly. could that spring be causing this hole problem?
Old 07-21-2016, 03:26 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
I got the injectors from Pensacola fuel injection . . .
That might be your whole problem.
Old 07-21-2016, 04:09 PM
sandflea1's Avatar
sandflea1
yea have not been happy with them. holly S@#$. that just totally reminded me of something. when I got the injectors from them I had 2 bad ones right from the start. they replaced one and told me to pound sand on the other one. so I replaced it with a used one from a buddy that owns a wrecking yard. and I did not put new O-rings on it. that injector happens to be on the driver side and that is the side I have not pulled the valve cover to check for leaks yet. I have tomorrow off so I will be tear that valve cover off to check it.
Old 07-21-2016, 04:48 PM
CampSpringsJohn
There's a few folks on here that we recommend for rebuilt or new injectors. And you will not get that kind of attitude from any of them. I hate to hear when a company won't stand behind their products.
And that drivers side valve cover may be hiding your problem!
  #28
Old 07-21-2016, 05:04 PM
sandflea1's Avatar
sandflea1
I hope that is where the problem is. I ordered a complete set of O-rings from riffraff that will be here tomorrow just incase that's the problem.
  #29
Old 07-21-2016, 09:37 PM
HKusp's Avatar
HKusp
HKusp is offline
Get that valve cover off and Cody test that side.
  #30
Old 07-22-2016, 07:20 AM
Tugly's Avatar
Tugly
Tugly is offline
No new O-rings on a stick swap? We're all but done with troubleshooting.
My own experience with Full Force Diesel has demonstrated that they go to the firewall to support their product.
Quick Reply: long cold crank no start hot
