Not Cranking Over
Old 07-18-2016, 09:02 PM
allenhillview's Avatar
allenhillview
allenhillview is offline
Not Cranking Over
Truck will not crank over. I know I can search but I'm down at the Grocery Store. Maybe someone will pipe right in.
Started truck 3 times in 30 min. no issues with truck before tonight nice well cared for truck. Went to get a pack of buns at store came out --NO CRANK--all lights are on dash, etc, new starter a month ago, relay changed out in fuse panel just to see if there was a change. Bought two new Motorcraft batteries installed , NO CHANGE, so is it natural safety, key switch, electrical ignition switch, solenoid on starter, is there a solenoid between key and starter? Help would be nice.
Old 07-18-2016, 09:09 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
Is it a crank/no start or a no crank/no start?
Old 07-18-2016, 09:22 PM
allenhillview
No crank , sorry I'll change subject
Old 07-18-2016, 09:36 PM
pirschwagon's Avatar
pirschwagon
pirschwagon is offline
Have you checked to ensure there is 12vdc @ the Solenoid?
Is there 12vdc @ Trigger Wire to Solenoid when key is turned?
Have you done a Voltage Drop Test to the Solenoid / Starter?
Check the attached....
Old 07-18-2016, 09:38 PM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
Relay on p/s fender. I installed an LED for this reason. As I the GPR-LED mod
Old 07-18-2016, 09:54 PM
allenhillview
Where is this on pass fender in an 02? I see the two near valley but is this glow plug only, where is this starter relay?
Old 07-18-2016, 09:55 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
No fender mounted relay on an '02 . . . Is it an automatic? Have you tried holding the shift lever up and starting, or starting in neutral? Is the shifter sloppy?
Old 07-18-2016, 10:07 PM
allenhillview
Yes and Yes, fooled with that shifter for a few, in neutral, at top with key in start mode , nothing, my shifter is not that sloppy never had to move for starting, its odd that there was no warning, inside store less than 5 min, truck is auto and miles are 155,000
Old 07-18-2016, 10:09 PM
allenhillview
Where is the 12v trigger wire come from? For starter solenoid on starter?
Old 07-19-2016, 05:29 AM
allenhillview
From another thread I found there is a yellow wire single pole terminal near pass battery I can jump over to check starter? Is this true on the 02? no relay or solenoid on pass fender? Where exactly is this single pole terminal near battery?
Old 07-19-2016, 05:47 AM
Pikachu's Avatar
Pikachu
Pikachu is offline
Yes, that's there on an '02. Disconnect the connector and touch the pin inside it to the bolt sticking up on the positive terminal. If it still doesn't crank, the problem is either in the short section of wire between that connector and the starter, or the starter itself.
Old 07-19-2016, 09:23 PM
allenhillview
Problem solved, Starter solenoid stuck, Its amazing what you see after you get your truck home by tow truck, sleep one night-think-go to work call all your buddies with 7.3's, talk to four shops you deliver parts to, read FTE thread, then take off wheel get down there with meter and boom see 12v at trigger wire. Thanks to all who piped in!!! Cheap starter but Warranty covered.
Thanks Allen
Old 07-19-2016, 10:41 PM
pirschwagon
Good deal. Glad you got it fixed
El Campo
1999 to 2016 Super Duty
02-13-2019 08:08 PM
tater3000
08-01-2018 10:55 AM
diamondjranch
09-25-2016 04:45 PM
lopitt85
17
09-23-2009 11:25 PM
nissan4life
13
09-20-2009 07:02 PM
Quick Reply: Not Cranking Over
