I think the tablet was overkill...
So this happened today.I think the tablet was overkill... but I use it as a nav + dash cam.. Gauges are finally operational..
Should my tranny be running about 170-180 in 90° weather? Seems a bit high.. and did anyone with the autometer boost gauge swap out the stock tube for something better? It seems flimsy and easily broken...
Aux 4 for high idle and probably auxiliary 3 for tablet charger (debating this..)
Why do I love this truck so much...
Mounting was pretty easy, I didn't want to put any holes up there so Home Depot sells these little magnetic things called Steelie car mounts. I used that and some adhesive. Had to add an additional magnet to the bottom side of the tablet to keep it stationary however later on I can just peel off instead of trying to cover holes.
Here's a picture of the underside.
Tad big for my taste, maybe a iPad mini would "look" better but I like where your going with the tablet idea! Your giving me some ideas, I'm looking into some new guages for my truck and not sure what direction I want to go...
Do you carry the tablet with you when you are not in the truck? I'd be worried about some ****** stealing it...also the heat in the summer if leaving it in the truck...
They are lighted, however the pyrometer is internally lighted. So I made the other 2 match with the little light bulb covers they come with.
They're all 2" and you can get them to match however I found a deal on each one off Craigslist so I Frankensteined em together.
Mounting bracket is auto meter and you can usually find the product inside a local Pepboys.
Installation isn't TOO difficult, however drilling into the manifold/intake elbow does scare people (I was terrified..). As long as you have patience it's a pretty cake job, just time consuming to do it right the first time. This is what I used as an install guide when I ran into snags.
Gauge Installations at DieselManor- 2003-2007 6.0L Powerstroke
Mark K has specified a couple of times that the 5R110 internal thermostat keeps the transmission at a minimum working temperature of 175°. If that is what you have then it sounds like it is functioning as designed. I wouldn't think the 4R100 would be much different temperature-wise.
