1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2011-2012 Master Cylinder Question
Old 07-18-2016, 12:19 PM
49fordv8f4's Avatar
49fordv8f4
49fordv8f4 is offline
I have a Motorcraft BRMC-144; BC3Z-2140-A master cylinder that I bought to use on my disc brake conversion on my 1949 F4. The MC is for a 2011-12 F450-F550 with vacuum boost and no trailer controls. I went to my local Ford dealer to buy fittings to use this MC and two of the techs there told me that I would not be able to use this MC because it is technically not a dual MC. They said that the port closest to the booster is a return port from the ECU and the front port is the pressure port. I put fluid in the reservoir and pushed the piston in with a screwdriver and it pumps fluid out of both ports. So, do I have a dual MC, or are the techs correct?
Thank you, Mark
mytoolman
04-09-2017 09:00 AM
Calbo3
11-28-2015 02:22 PM
mudrunner4ever
04-05-2013 06:35 PM
ranger250Center
03-18-2006 10:00 PM
koshare
11-20-2002 08:31 AM
Quick Reply: 2011-2012 Master Cylinder Question
